0 Members and 52 Guests are viewing this topic.
marathonman
I request that people please stop posting book long post of giberish. please read the patent. i repeat, PLEASE read the all patents before you post half a page of nonsense.
the Rswami device is not Figuera device period, it's a transformer, and as such i request you move off this thread as it does not pertain to the Figuera device at all. please move off this thread and get your own thread as you are disrupting the very fabric of this thread.
Dear Ramaswami,why are you so aggressive ? :-\
My first given example was an inventor device from India,too:
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DE&NR=2733719A1&KC=A1&FT=D&ND=3&date=19790215&DB=EPODOC&locale=en_EP
Kalicut/Calcutta
It looks really simple
( comparing with this not more years less younger concept of an optimal efficiency machine
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19801209&CC=US&NR=4238717A&KC=A )
I am -your findings and your person related- neither your enemy nor your friend ! ???
The Figuera device is one idea,magnetic force amplification to convert this in a work process to electric power another
and finally also your -"earth (battery)cell"effect similar- findings.
If it is simple : Bravo ! If it uses no/rare material comsumption: better !
                                   If it is economical : HEUREKA !
here an experimeter store: https://web.archive.org/web/20030601205520/http://www.theverylastpageoftheinternet.com/forsale/store/contents.htm
with free e-bay plans:
Earth Battery , your point recitating
"The result has been explained here after several months by a Chemistry Professor that we have caused an electrochemical reaction in the Earth points by the high voltage differences and that is the reason for the higher output. The Professor guaranteed that the same result will not come again after a few days as the electrodes in the Earth point would have got oxidized and corroded and output would be less. He turned out to be correct."     related.
But using copper wire ,not iron wire ::)
I have no problem with simple results.
Do you know this "water-egg/granate" concept,not consuming the device,
only refillable water+coal powder as fuel :
https://worldwide.espacenet.com/publicationDetails/description?CC=FR&NR=633752A&KC=A&FT=D&ND=3&date=19280203&DB=EPODOC&locale=en_EP
but doing the math:
Un exemple : il est avéré qu'un minuscule  récipient cubique de   o-  3o (le côté, d'un  poils moyen de 15   kilogs,  en pleine   charge, contient 55o éléments complets dont voici la  puissance électromotrice Tension : 66o volts.
    Intensité : 1,5 ampères pour une. Résistance intérieure : de   44o  ohms.  force qui ne se dégradant que de   i  !à volts par  heure, laisse une   marge  de  force utile  lar gement   suffisante  pour entraîner un moteur  de   1o  HP à   15oo tours, durant 3o heures  au minimum,  force à   peu  près gratuite et renouvelable à  tout instant par une simple   réimbibition  des  sachets de charbon (opérable en quelques mi  nutes).
660 V x 1,5 A =  990 VA                  x 30 hours/heures(au minimum ::) )      = 55 "water-eggs" á 12V
10 hp motor ~ 7450 W(VA) motor  x 30 hours   = much power        :o full load ?
                                      carbon + zinc + water : with no emission
                                   (990VA x 30 hours)/15 Kg 1928 publicated :
                actually 2016 a recycleable battery available with that power storage ?
                   only as       carbon  +           water :     hydrocarbon fuel cell
without doubt: it is written !
with      doubt: it is as working ?
forest,yeah,but the water(hydrogen/oxygen=radical) does the catalytic effect !
Your example: not water,but sulphur ! probably + ambiental oxygen (air and rain/fog water)
from the US160152 description: primary -without insulation
North/south orientation is known by Bioculture or http://www.electrocultureandmagnetoculture.com/links.html !    http://www.rexresearch.com/hhusb/hh5elc.htm
Stupid humoric question ,related this "rexresearch article" sentence
Under the influence of the electrical current, the numerical proportions between ( hemp) power plants of different sexes :
is your generated electricity male :P or female  :-* ? Transgender :o
NRamaswami
lancaIV..
Sir I apologise if you found my language to be aggressive. I do not understand the French or Spanish in your posts.
The way Earth points are made here is simple.
One iron pipe of 2 inches wide and 8 feet length is inserted into an Earth pit filled with charcoal and water and salt ie sodium chloride. A copper wire is connected to this Iron pipe. That is all.
Copper plates are easily oxidised and wasted than steel. The good materials are non mgnetic and non corrosivec steel or Titanium. Submarine grade material.
I have not studied much about these concepts. I share what I did and what I found.
Chris Stykes the other day mentioned that when core is saturated the wires wiund on the core will behave only like resistors and there no phase or frequency difference. In 2013 we did not know any thing. But later on another friend advised us that the safe limit is 1.2 Tesla and 12 amps is the safe limit for current in 4 sq mm wure when it is coiled. When we followed these safety limits we could not cross cop=1 itself.
I used very cheap material.soft iron rods hammered in to plastic tubes made the core. And we used first copper and then aluminium insulated wires. Soil content can change the results as are the materials used for the core. But we can prepare the soil.
I think since we had an air core plus iron core we could go to high Tesla ranges and still it was safe for us to get results. Normal solid cores would have resulted in so much of heat that wures would have burned away. I have several copper wures that have got the color of copper changed to slightly black. I think it is due to excessive heating due to high saturation.
In all honesty I did not know why and how those results came. I am trying to understand.
Patrick has warned me not to try to do any self runner as the system will then try to take energy from the atmosphere and it results in lightening strikes and lightening prefers living beings than metals to strike. So I have avoided doing these things.
I have zero knowledge in other things. The professors here would have dismissed the statements and observations except for the fact that I handle their patents and they know me to be honest and trustworthy. This is how they looked at
the Earth point possibility. We need to use non corrosive material for Earth. Copper would easily be oxidized and it is more expensive and will  easily stop the desired work.
I lack specific knowledge on this subject.
The Earth points have to be kept wet for results to come.
We did a lot of things wrong and today I can say if you follow safety norms we will not get results we got. There is also the possibility that iron rods in the core oscillated increasing frequency. But I do not know these things.
You can look deeply at the Figuera device and see if any component is missing or if the patent could have been edited. We found two anomolies.
The 1902 patent says that induced must be placed between opposite poles. We found that it is identical poles that give best results.
In 1908 patent it says the two magnets must have alternately higher and Lower magnetic field strength. We observed that both the primaries must be of equal or nearly equal strength to get best results. Since we used AC the oscillation is there always.
Please do not trust patents. They can be used only as guiding materials. They are wriiten to hide real facts.
I do not understand any language other than English and Tamil and if my writing style is found to be aggreesive I apologise again.
Ramaswami
