marathonman
Acca;
Thomas Townsend Brown Electro-Gravity Device system could quite be in use but that is beyond the scope of this thread.
Regards,
Marathonman
marathonman
It is quite amazing once you realize with the change of inductance the current flow will be reduced just how smart Figuera actually was in using an active not static inductor in his system. running current through one loop of wire over an Iron core will not change the current much at all but adding multiple loops to the core then you will have much more self inductance as the loops magnetically link to each other increasing the opposing magnetic field to current ratio. then using a closed core controller you will achieve an even higher efficiency with very little flux loss.
since the magnetic field is basically the brakes to current flow the larger the magnetic field the lower will be the current flow. as Faraday's states for any induction to take place all that is needed is for the magnetic flux to change within the circuit and never states anything about current. since we are using DC in the system the circuit has to be changing at a constant rate or self induction will cease.
so Figuera used an Inductor that has a positive moving contact that constantly changes the amount of loops that magnetically link to the circuit and in doing so constantly changes the intensity of both magnetic fields on either side of the brush that cause self induction within each independent sides of the circuit to take place.  this is in exact accordance with Faraday's Laws of induction.
If you have two negative sides to an Inductor with a moving positive brush contact,  you will in fact have two opposing magnetic fields at the positive contact that will keep those two sides of the circuit completely separate but in complete unison.
thus the end result that Figuera achieved was two electromagnets that increase and decrease in absolute unison which is required in order to maintain the required pressure between them and on going induction to take place. the magnetic fields will never combine yet the Electric fields are positive and additive.
then on top of all that, when one side is reduced that portion of the reduced magnetic field is released into the system combined with the reduced primary potential to off set the rising side voltage drop as any increase in magnetic field storage will cause a voltage drop in potential. he then looped back a portion of the output just like a standard generator, to replace the losses occurred and give rise to amplification to the rising primary.
Sheer Genius!
Marathonman
marathonman
When the primaries polarize the secondaries it would seem that the South end of the secondaries are attracted to the north face of the opposing primaries but as current starts to flow in the secondaries and the load the Lenz Law comes into play developing a North Opposing field inside of the secondary. it is this field that is pushed from side to side across the secondary through the Electric field formed by the primaries.
the sweeping action of the primaries being raised and lowered with the North opposing field of the secondary being sandwiched in between them gives the secondary the illusion of motion to the Electric field. this is exactly like a standard generator as it to has to have motion through the Electric field in order for EMF to occur. the Electric field in a standard generator is stationary so the rotation of the rotor is used to induce EMF thus just like a standard generator the Figuera device uses the sweeping motion of the primaries with the opposing field of the secondary between them to induce EMF.
according to Faraday's Laws of induction to occur there has to be motion of either the field or the wire and that is what is taking place in a standard generator with the rotation of the rotor. in the Figuera device the sweeping action of the primaries from side to side with the opposing field of the secondary is this the very motion needed for EMF to occur. even though it is more like virtual motion it is still motion needed for EMF to take place.
thus in complete compliance with Faraday's Laws of Induction.
Regards,
Marathonman
AlienGrey
Quote from: norman6538 on July 13, 2018, 08:25:46 PM
Thanks Marathonman for your comments but I never heard of
  "the 1932 Coutier device"  do you have a reference to that.
I understand what the flux change does without motion but the trick
is how do you embody that? I've read and tried but simple setups
have not been successful and no one to date has done that either.
Norman
do you mean Tesla's Unipolar Dynamo by any chance ?
marathonman
No ! i mean the 1932 Coutier device. pronounced Cou-Ti- ay
I posted the link in post 4413 to Norman.
Regards,
Marathonman
