marathonman
I finally figured out how to precision grind my part G to perfect flatness. i will be purchasing a table top Drill at either 2800 or 3100 RPM then attach a 7 inch sanding disc. this will buff it to perfectly flatness for the brushes to glide on eliminating all imperfections. ;D ;D ;D
Regards,
Marathonman
marathonman
Fished bobbin ready for some light sanding and painting. these bobbins are rock hard and slide right over the core plus are cheap and easy to make. they can be made square or rectangle for your core really making it easy to wind your primaries and secondaries.
i will say this though, do not use plastic below when attaching the end pieces as it cause it to ripple from the heat or the chemicals. the ripples made it hard to get a smooth flat end cap. the other time i made these i soaked a 2x4 with light oil before i made the end pieces.
Regards,
Marathonman
marathonman
I see the guys on Entergetic are ripping each other a part. to bad none of them actually know how this device works. :o
one bloody mess if you ask me. ;D
Marathonman
marathonman
I would also like to add more information on that 1 kilowatt output, 14.8 lbs per square inch 7.4 per primary.
in order to induce movement into the secondary Figuera had to reduce one primary and raise the other to get the sweeping of the secondary across the electric field. in doing so the reducing primary is reduced hypothetically 30 percent while the other is increased to get full sweeping action of the secondary.
so if you reduce one primary 30 percent that means from 7.4 lbs per square inch to 5.2 lbs per square inch while the other primary is peaked at 9.6 lbs per square inch. the rise in the primary is from the amplification factor of the two reducing potentials and the secondary feed back combined giving the needed amplification to the rising primary electromagnet. from this action both primaries will always maintain the 14.8 lbs per square inch across the entire length of the secondary needed for the 1 kilowatt secondary output. these numbers are not exact but at least you get the idea of what needs to be done in order to maintain the output and how it is done.
the primaries must be built with these parameters in mind yet still avoid saturation.
both primaries at any time will add up to the total output of your secondary. one increasing in pressure the other decreasing in pressure but both pressures equal the needed secondary output pressure at all times.
now try that without part G inductor using electronics..... NOT !
Regards,
Marathonman
marathonman
I have no days off this week except Sunday so i will be winding the rework primary then and hopefully post so pics of the finished primary.
Regards,
Marathonman
