0 Members and 62 Guests are viewing this topic.
seaad
See corr above.
Dead short thru 1/4 turn of G-coil !
Regards Arne
marathonman
At that position of the brush the commutated secondary is at ZERO so there is no dead short. plus i am using a 16 pole commutator with one pole not connected at that point on each side of part G. and that is every 1/2 turn by the way not 1/4 turn.
The way i see it there is only two ways to get the loop back function. the way i an trying or using the Tesla AC to DC one side connected to the positive brush and the negative connected to the negative side of the primaries. that way it allows current to circulate around the system remembering part G becomes the supply once the starting is removed. the secondary loop back can then be commutated and the positive connected to the positive brush and the negative side connected to the negative of the primaries. this will give the added boost to the rising primaries. i see no other scenario but these two cases.
Regards,
Marathonman
seaad
Not a 1/4 of a brush rotation on top of the G-coil.
But a short cut thru a 1/4 of a coil turn. From + to - via the coil cupper wire.
Regards Arne
marathonman
Tell me WHAT you see as a short. the secondary will add to the magnetic field of part G through moving contacts which will add to the potential being circulated in the system. the secondary at that time will be ZERO.
any power running through part G will have magnetic resistance and will not be a dead short but add to the system potential in the form of a magnetic field.
IF i find it to be incorrect i can very easily change to the only other option with the Tesla AC to DC patent addition and removing the second brush. until then it stays in my build.
Regards,
Marathonman
seaad
Quote from: marathonman on September 07, 2018, 03:26:07 PM
Marathonman
Pls see pic.
Between the brush with +voltage and the brush with - voltage is it a piece of a wire, a (1/4) part of a turn in the G- coil at that time and actual ?-? position.
When puttting a short piece of wire beetween battery poles what happens?.  Spark= short cut.
But a wire diagram as I asked for long ago maybe could help missunderstandings.
Regards Arne
