0 Members and 37 Guests are viewing this topic.
marathonman
The closer we get to the truth the more the rodents come out of the wood works. NOW the lousy BroMikey is attacking Entergetic and even my you tube channel running his mouth. it seams the truth has many, many paid misinformants running  scared scrambling to discredit and disrupt the threads on Figuera.
there is no way one can discredit the truth and i deplore every reader to do small tests at your own home to verify EVERYTHING i have posted is exactly TRUE and always has been.
the world will have the Figuera device no matter what they do. then after that i will cram the 1932 Coutier device up their ARSE and laugh while i am doing it.
we are the ones in control NOT THEM, only we can decide our destiny NOT THEM.
good day people and happy building.
Regards,
Marathonman
marathonman
Three ways to increase your electromagnet strength and speed of the reaction of the primaries.
1. Reduce resistance. Self explanatory.
2. Another way of increasing the current is to use a higher electromotive force, or voltage. The relevant formula is V=IR, the definition of resistance. If V is the drop in electric potential over the entire circuit, and R is the resistance over the entire circuit, the current (I) through any point of the circuit can be increased by an increase in the applied voltage. this is why Figuera used 100 volts and the fact that the secondary feed back to part G with the other added potentials equates to the amplification factor adding to the peak of the rising primaries.
3. using DC instead of AC. (Self explanatory) the main reason all generators use DC to excite it's electromagnets. AC has to flip all the magnetic domains thus takes a considerable time to do so and will loose induction in the process. thus the reason DC is much more superior in every way and why Figuera used DC in his device.
4. wind the coil the entire length of the core.
Just because someone doesn't have a lot of money for their build does not give anyone the right to belittle or attack them. all it mean is the money is tight and has absolutely nothing to do with the their knowledge of the device. usually it is the attacker that is the total ignorant one knowing nothing of the device . that and the fact that some are paid to disrupt threads and these type of people are the lowest form of human beings there is that would probably sell out their own mother for a buck.
if the human race is to survive we have to stick together bringing these devices forward if we are to survive the destruction of our earth and it's resources from our government and corporate world.
this device works whether the opposition likes it or not and all it takes to prove it is a few tests on your bench.
Regards,
Marathonman
Regards.
Marathonman
marathonman
My brush holder is finished finally but as of this moment i so not have the cash to pay for it. as soon as i get it i will post a pic of it and as i progress in the remainder of my build.
Regards,
Marathonman
marathonman
I find it funny and some what convenient  that through out all the years of my research not one university anywhere has information on an active inductor. all they describe is a static inductor with changing current and not one single one states that if L changes so does (I) current. they are mutual as either of them changes so does the other.
if I changes so does L but the flip side of the coin that is not published anywhere is that if L changes so does I.  this is the magnetic flux to current ratio and at any given time that the magnetic flux increases or decreases (I) the current flow decreases or increases respectively. as each loop is added or subtracted to either side of the rotating positive brush in part G of Figuera's controller the magnetic flux to current ratio is changing constantly. as each loop is added to that side of the brush the magnetic field around that loop interacts with the loop next to it and it is this interaction that produces an EMF which is in exact accordance with Faraday's LAWS OF INDUCTION and according to the Lenz law this EMF produced within the circuit it's self will oppose the original current flow.
if Figuera had used a standard resistance wire the system would have so much losses through heat that i really doubt the device would ever self sustain. but since he did not use wire resistance  he did not have a heat death device.
Figuera chose an active inductor for many reasons and one of the main reasons by using a magnetic field to control current flow allowed him to attain efficiencies well beyond that capabilities of resistance wire. using thicker wire on his active inductor Figuera was able to achieve efficiencies in the high 90's with very little core and ohmic losses.
the act of using magnetic flux to control current flow was down right genius on Figuera's part that not only allowed him to store and release potential within the system at specific times but to split the feed into two active circuits controlling current flow of two separate feeds in complete unison.
I salute the sheer genius of Figuera as his device has completely captivated me beyond belief.
even after all this time i still stand in total Awe of Clemente Figuera.
Regards,
Marathonman
marathonman
It seems i am finally getting through to people. many more are PMing me on multiple site stating they finally get "IT" what i have been posting for so many years and to me that is totally awesome.
keep on reading people and study what has been said until the light bulb lights. NO ONE can stop the transfer on information nor can they stop you from building the Figuera device.
screw our Governments and the corrupt Corporations that control us bind us into human slaves.
read, understand, build and be free.
Regards,
Marathonman
