ourbobby
Hi marathonman,
                         Thank you for your reply. I have also been asking myself questions regarding the interpretation of the G rotor. On the patent - 1908 - all the connections are in pairs. I do not recall seeing where the exciters are numbered, so I take the connections as the default numbering. That said, When 1 is first cab off the rank so too is 16. As we move around number 2 is coupled with 15 and so it goes. I would read this as a progressive DC coupling simulating the  passing of two external magnetic fields. By so doing this sequence will produce a series of pulses as the output, leaning toward a DC complement. To get AC, the sequence has to be dramatically changed, and this is a later alteration to the patent. I do not see this coupling or it mentioned in the patent. Although I seem to remember, either Hanon or UFO stating that the later patent was 30 or so pages long. I do not speak Spanish, so I could easily have missed this point.
The reason I have gone over this part of the patent is because I think I am missing something somewhere. You are correct when you state it all depends upon the G continuum. It is just that in my naivety, that I might not have learned enough yet. And, that I see the role of the G continuum as being different to the proposal you are offering. Herein lies the issue. Having learned something, we wish to change it!
I mention radium as this was an element used for its usefulness until it was realised that people were dying from exposure. A short cut so to speak. The Tesla reference, for myself, is a better solution. And the Patent reference fits into the time frame. It would require re configuring  the G continuum rotor and its application and connections and adding other components. I hesitate to do that because I would not like to interfere with contributors such as yourself by inferring that you are wrong. When in fact I might easily be missing the point.  Yourself and many other on another forum have made massive and unselfish contributions to the Figueras knowledge base. My knowledge base especially, to the extent that I think I might be wrong! And, I do not wish to make any inferences against anyone, when it is clear the level of expertise that comes through in many of the posts.
My previous post was just my expression of looking for a solution to what I see as a problem.
Once again, thank you for your contributions, were it not for those, I might not be here!
Dwane
forest
Yeah,looks like the answers are on this page . While I don't  accept the [size=0px]marathonman [/size]notion of using part G I agree energy is reused in somehow similar manner. What is hidden is quite easily to be found in Figuera patents covered by some cryptic sentences .
forest
I'm quite sure any lab with sufficient amount of donation and clever stuff experienced in magnetism would sove this mystery very quickly.
Quote from: marathonman on February 27, 2019, 10:22:59 PM
IF no one can understand this Graph then there is no hope for the person trying to understand it. don't worry about the wording just concentrate on the direction of the fields as per the increase and decrease. this is the reason we have overunity because the Motional Electric field does not conform to the laws of conservation of energy and the fact that the exciting system potential is reused not destroyed.
Regards,
Marathonman
                                                      F(Coulomb)/F(Lorentz)
https://www.didaktik.physik.uni-muenchen.de/elektronenbahnen/b-feld/anwendung/geschwindigkeitsfilter.phptranslated,
caution by this automatic translation : not Vienna but Wien https://de.m.wikipedia.org/wiki/Wilhelm_Wienhttps://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.didaktik.physik.uni-muenchen.de%2Felektronenbahnen%2Fb-feld%2Fanwendung%2Fgeschwindigkeitsfilter.php
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=4&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=ES&NR=2265253A1&KC=A1#
marathonman
It would be very much appreciated if the scumbag LankaIV would stay OFF THIS THREAD. go bother some other sorry thread and leave this one alone. your dog dew and contribute NOTHING so GO AWAY !.
and contrary to some the answers are on these pages just some are not bright enough to see what is right in front of them or from the classical training of corporate controlled college system. but that is just my opinion.
ourbobby;
The potential is not pulsed it is just raised and lowered in each primary set 180 out from one another. as part G spins it is constantly changing the magnetic flux to current ratio and when this happens you will get an increase and decrease in current flow at a constant rate. at no time is the current interrupted. the goal is to sweep the magnetic fields just enough to clear the secondary then back to full potential.
the reason no one is getting nothing out is the inverse square law is biting them square in the arse which i have explained. please don't be side tracked by fools,  do the tests and verify for yourself what has been shared. remember your swimming in a fools pond on this site that are desperate for for some quick bait.
Regards,
Marathonman
