ourbobby
Hi marathonman,
                         I am having cut 16 at 3" and 8 at 6". Using the notional balance for 3:1 ratio for length and diameter from the book The electromagnet by Silvanus Thompson and your advice for flux between y and NS coils. Great little book to help focus on what you are trying to do! Although some of the terms are quite archaic, but, it is helpful channelling one's thoughts.
ourbobby
ourbobby
Hi,
    What I have not been able to reconcile yet is the comment that for 100w in 20kw out! Something else must be going on which is not in the patent.
ourbobby
ourbobby
Hi,
    sorry to go on about this, but a 200 fold increase from 100w to 20Kw is an unbelievable increase. Especially as some of the outcomes from tests so  far have been underwhelming. Even if the unit was resonantly tuned, I doubt Figueras would get that much increase. I can only see two realistic options for this output.
1) He painted his coils or cores with Radium. Perhaps that is why he was sick and died. Not knowing its contagious dangers.
2) He was familiar with Tesla's British Patent 11293 for the Magnifier Transmitter ( lodged 1901), and worked out how to utilise this information.
I shall still proceed to build the unit, but, I must admit, I am feeling a bit skeptical. Still if as one of the builders on the Energetic forum has indicated a 3 fold output - COP >3, that should work! Let's not be greedy!!
ourbobby
marathonman
Figuera did NOT use Radium like other cheaters, he used common sense as a Physicist.
What people fail to realize is the power in the exciters is recirculated through out the inducing system which includes the Primaries and Part G, the controlling Inductor that stores and releases energy at the proper time unlike a resistor that waste potential in the form of heat unrecoverable.
the 100 volt, 1 amp or so per your system is used to excite all the inducers not just one so the reducing side releases potential into the system to off set the potential drop of the rising side. the added secondary loop back is there to replace losses and to give rise to amplification as all potentials released are combined  causing a voltage increase that will allow more current to flow in the rising primary. it is called forward biasing in laymen terms.
each side is either reducing or increasing in potential which is either releasing potential into the system or storing into the magnetic field to off set the next half cycle of reduction.
Regards,
Marathonman
marathonman
IF no one can understand this Graph then there is no hope for the person trying to understand it. don't worry about the wording just concentrate on the direction of the fields as per the increase and decrease. this is the reason we have overunity because the Motional Electric field does not conform to the laws of conservation of energy and the fact that the exciting system potential is reused not destroyed.
Regards,
Marathonman
