0 Members and 31 Guests are viewing this topic.
floodrod
No luck on the clamp that big.
Bobbin is 35mm x 35mm.  44mm long.  Wrapped with 24 gauge. 500 turns. Ohms out at 6.8 ohms.
First test results:
Measuring amperage of the supply with various frequencies. Core and no core..  1 coil from amp channel to power supply ground. Positive biased triangle wave. Power supply locked at 12V.  DC reading after rectifier to supply ground.  Not returning through rectifier negative.  Voltage is 5.6V from rectifier positive to supply ground. (under 1/2 for various reasons)..  Just testing reactance from positive biased wave 1 coil.
25 Hz-  W/core= .578 Amp.  No/Core= .647 amp
50 Hz-  W/core= .487 Amp  No/core= .607 amp
100 Hz-  W/core= .434 amp  No/core= .532 amp
500 Hz-  W/core= .416 Amp  No/Core= .426 Amp
1000 Hz- W/core= .417 Amp  No/Core= .419 Amp
5000 Hz- W/Core= .422 Amp  No Core= .422 Amp
10000 Hz- W/Core= .431 Amp  No/Core= .431 amp
20,000 Hz- W/core= .495 Amp  No/Core= .495 Amp
25000 Hz and above-  Can't measure.  Scope shows solid 12.5 Khz and will not increase.  Guessing end of limit for the amplifier.  Somewhere about 5Khz, the trend starts reversing and the core makes no difference.
Attached single wave and also full dual waves all on positive bias 180 shifted.
I will repeat with 2 coils / cores attached.  See how they interact with the opposite wave next.
floodrod
2nd test Results:
Both coils, 180 degrees out of phase.  With cores touching each other.  Can't measure under 100 Hz without changing Supply voltage, so starting at 100 Hz.
North to South-  (The way that should not induct good).
100 Hz-  .831 Amp
500 Hz-  .783 Amp
1000 Hz- .780 Amp
5000 hz- .784 Amp
10,000 hz- .790 amp
20,000 hz- .861 amp
North to North (The way they should induct).
100 hz-  .780 amp
500 hz-  .766 amp
1000 hz- .766 amp
5000 hz- .771 amp
10000 hz-  .780 amp
20,000 hz-  .850 amp
No sign of Back-EMF making it back to the positive in any configuration yet.
Next 2 tests-  Check a choke response with a closed core.  And test all this with a pickup coil between.
alan
Quote from: forest on April 30, 2023, 09:36:17 AM
"when the induced is approaching the center of another electromagnet with opposite sign to the first one."
Exactly, and the diagram of a regular dynamo shows N and S to indicate the poles.
Also: "since any variation occurring in the flow traversing a circuit is producing electrical induced current "
N-N would be a moving monopole field which may have desirable effects too.
https://www.youtube.com/watch?v=aCClYZp9Yls
https://www.youtube.com/watch?v=gWcPcOg_yc0
https://www.youtube.com/watch?v=P3Enr6_d3yU
https://www.eeweb.com/a-flash-from-the-past-figueras-generator/
forest
"N-N would be a moving monopole field which may have desirable effects too. " but it's completly different story.
floodrod
"when the induced is approaching the center of another electromagnet with opposite sign to the first one"  <---  he was describing how a regular dynamo works..
With 1 way current, growing and shrinking 180 degrees out of phase, the only way it will induct is Like Polarities..
Shrinking North acts as South..
Shrinking South acts as North..
Growing North acts as North..
Growing South acts as South..
demonstrating this on a live bench.
https://www.youtube.com/watch?v=3Syk9t7foYQ
