NRamaswami
I went through your video.. It is an air core Tesla coil. Did you convert the voltage increased to usable power? There is no indication that for 75 watts input that it produced 30000 watts output but I agree that if the voltage increases the amperage should also increase.
Please see this http://www.physiotherapyequipment.in/short-wave-diathermy.html
It is a physiotherapy equipment used in India and even a fused out tubelight will be lit brightly if we show it six inches above the condenser pads..The pads radiate out waves in radio frequency and that heats the gases of the tube light and even if it is fused out would glow brightly.
1. Contrary to a Tesla coil, Figuera used iron core and the results are not peak output but sustained output. I say this for we have used the primary, in another experiment, not as electromagnets but to power the lamps. 10x200 watts lamps and the secondary was able to light up to 5x200 watts lamps. This was done for tests and for safety considerations. However the combined output in this case is less than the input.
2. It is only when we make the primary work like electromagnets we get more output than input and I believe that is sustained one. I will do the tests and then I will inform you. If the results are negative also I would inform you.
In the system on the para marked 1,  I think that there is a variable frequency driver controller circuit used in wind turbines and Alternators and if it is used in the system as described the voltage in the primary would not drop and the usable output would be more than the input. But I need to check and test them.
I find that Figuera's statement and Buforn's statement that electricity comes from interactions of atmosphere and earth to be correct on experimental basis. So I believe them. Of course they are more than 100 years old. I believe that the Tesla coil secondary also is earthed at one end and the increased output is due to using high frequency and connecting between the atmosphere and earth. But I have not built or experimented with a tesla coil. So I really cannot comment.
I will take a minimum of two weeks to come back. I'm not loaded with cash and I have to put in my own money to do these tests and report. But I will come back and you can see for yourself.
NRamaswami
I will need to agree with you on Transformers if you consider Tesla coil to be a transformer. By Transformers I meant commonly used transformers and did not consider Tesla coil which outputs high voltage and cannot be used to generate usable power. To my limited knowledge.
We have used an Electrician, voltmeter, ammeter, and a multimeter and no voltage showed up in the primary. The current used was AC as you rightly describe. The iron rods have high impedance again. But the magnetism was enormous but there was no power to the lamps. Not even a single volt..That was the amazing thing..How an electromagnet can block about 2000 watts of power from getting through the wires wound around it is not understandable by me.
The results are perfect. And I do not cheat and I do not have the kind of your knowledge and so I do not intend to teach or pretend to teach.
Your language is very strong and so Hanon feels agitated. I take it in a friendly way and am not disturbed for I only report the factual findings here so others can also benefit. Nothing more. I do not know any one here and I do not know people personally and do not take things personally.
I apologize for any miscommunication and let us carry on. But give me a break for two weeks. And try to replicate the results and check for yourselves.
Newton II
Power is defined as "rate of work done"
Think that you have 100 Joules of stored energy.  You can dissipate it as 10 Joules in 10 seconds (power is 10 Watts), 100 Joules in            1 second (power is 100 Watts), 1000 Joules in 0.1 seconds (power is 1000 Watts), 10,000 Joules in 0.01 seconds (power is 10,000 Watts) and so on ...
In all the above instances if you multiply watts with time,  you will get energy as 100 Joules which is conserved.
A simple example  -  If you connect 3 Watts bulbs 100 nos. in parallel to a battery,  the battery dries out quickly delivering 300 Watts.  But if you connect just one 3 Watts bulb, the battery retains its charge for a very long time delivering just 3 watts.
I think this is just high school physics and no electrical engineering is involved in this.
gyulasun
Quote from: NRamaswami on February 15, 2014, 09:08:37 AM
...  We got 630 volts and 20 amps in the Ammeter at no load. Since this was way too high for us we stopped. We need to build a transformer to step down the voltage to around 200 volts and then give it to the load lamps to check. Secondly I have had
50 Amps Ammeters burning out after showing 50 amps at no load. I would not believe that there was amps at no load if the Ammeters had not burned out..
Hi NRamaswami,
Would like to ask on your 20 Amper output current measurement you performed on the secondary with 'no load'.  I guess that you connected the Ampermeter directly across the secondary coil,  actually measuring the "short circuited output current" of the secondary coil, was this so?  If yes, then you actually had a load: it was the inner resistance (impedance) of your Ampermeter, ok?
But then your earlier measured 630V voltage (which I assume was measured across the open secondary coil) was divided between the secondary coil's inner impedance and the inner resistance (impedance) of the Ampermeter: these two impedances were in series from the 630V induced emf point of view and you can surely understand that due to the voltage divison across the series impedances,  the bigger part of the 630V induced emf remained inside the secondary coil (and got lost as heat as in any generator) and only a smaller part of it remained for the Ampermeter which was willy-nilly the 'load'.  This is because an Ampermeter has a much less inner resistance (impedance) in the 20-50 Amper range than your described secondary coil impedance has.
So what I mean here is that your output power cannot be calculated by multiplying the 630V with the 20A if your ampermeter was indeed used to short circuit the secondary coil.
Perhaps a possible solution to step down the 630V output voltage is to use 3 identical off-the-shelf 220V step down mains transformers and connect their primary coils in series, and also connect their secondaries either in series or parallel as need arises.
OF course the simplest solution would be to use less number of turns for the Figuera secondary coil so that it can output less than 630V.
ONE more thing I would like to ask: did you monitor the input current when you were measuring the 20 Amper 'no load' current in the secondary coil?  I.e. did you use an Ampermeter also in the primary coil between one of the input mains wire and one of the primary coil input wire? I am curious how the input current changed (if it changed, that is) when nothing was attached to your secondary coil and then you attached the Ampermeter to the secondary?
Putting this otherwise: how the Figuera transformer behaves for a short across its secondary?  (here I assume the Ampermeter shorted the secondary coil)
Thanks,  Gyula
NRamaswami
The secondary was not shorted. It was kept open. Not connected to the load. We kept it open to check what is the voltage. We expected high voltage but did not expect the Ammeter to show the Amps and did not expect to see such high voltage. So we immediately switched off.
Both Primary and secondary had voltmeter and Ammeter connected separately to them. This why we are able to say what is the input voltage and amperage and what is the output voltage and amperage. Input voltage is 220 volts and 7 amps. Output is 630 volts and 20 amps. We need to put a step down transformer to see that the output is not peak output as it happens when we switch on or switch off but sustained output.
We have tried to reduce the input voltage and lower the input voltage, lower is the efficiency of the device.  If we reduced the turns of the secondary as you say we could check what is the amperage in the secondary but my feeling is that lower the voltage in the secondary, lower would be the amperage. Doubling the voltage would quadruple the amperage is something that we read about secondary output. So if we reduce the turns to reduce the secondary voltage, we may not increase the amperage in the secondary. The system has to increase both voltage and amperage but then must be stepped down using a powerful step down transformer that can take up to 100 to 200 amps. That would be costly and would need to be custom built.
My guess is that Figuera drawings are showing 7 different modules the result of first one feeding to the second and the second one feeding to the third and so on.
Probably then the rotary device was intended only for the first module with the rest of the other modules not being shown by him.
I had given 12 volts and 16 amps to the module also and found very little increase in the output. Unless we increase the input voltage, the secondary does not perform.
Power given in Watts matter but of that power Voltage must be at least 20 times higher than the Amperage for the device to show efficiency in the secondary. Since magnetic field strength depends on number of turns multiplied by amperage, there needs to be a reasonable amperage for the device to work. If the 20:1 minimum ratio for the input voltage and amperage is not there, we do not have any results.
If we give high amperage low voltage, magnetism is high but the resulting induced electricity is not high. If we give the same wattage with high voltage and lower amperage combination the resulting secondary performs well. I do not know why again....But this is the result we got..Probably the induced emf is higher when the input voltage is higher. I have read that we can increase the frequency of the current for a low amperage to get a high induced emf  and secondary output and probably the rotary device of Figuera by producing sparks achieved that as well. I do not know. Sparks have high frequency I guess.
The frequency used was the mains frequency of 50 Hz only..We did not give high frequency. Plain simple normal mains AC was directly used to generate the electromagnet.
We will build the device again and add a step down transformer and then would inform you all. But it will take 2 to 3 weeks depending on my workload. Thanks and will post my replies only next week. Until then please bear with me.
