0 Members and 113 Guests are viewing this topic.
Newton II
Quote from: NRamaswami on February 18, 2014, 05:46:41 AM
Do you mean to say that we must provide exact wattage consumed by the primary back to the primary for it to self run or in exact voltage:amperage combination apart from exact wattage.. For example if I provide the feedback from a lower voltage and higher amperage but similar wattage as feedback from thick wires,  would it become higher voltage lower amperage combination automatically due to the fact that the primary has thinner and so higher resistance wires..Can you clarify on this point please.. I'm obliged..
1) Think that starting input wattage is 'X' and output wattage is 6X (as you said earlier 6 to 8 times),  send some  1.5X watts back to
     input primary assuming for losses and balance 4.5X watts you can make use of.
2) Instead of connecting secondary directly to primary, connect it through step down or step up transformer as the case may be to get
    exact voltage required by primary.
NRamaswami
Hi:
Thanks.. We will try to rebuild it. It may take till Saturday or Next Monday. I will come back after that. We will first check whether the output is exactly 6x times as all are doubting the 20 amps output figure. We will check if the doubts are valid or if we made a real breakthrough. We will simply report the facts. If the voltage is very high we will step it down.. That will take building a custom built transformer to reduce the voltage to 220 volts and then connecting to load to check what is the output. If that output is positively 6 to 8 times higher as I believe it should be, then we will try for the self sustaining part. Others can also come up in the meanwhile with their results. They can validate or negate my results. ok. I think this is fair for now. Let me now focus on my work.. Bye.
NoMoreSlave
hanon
Hi all,
As refered previously in the forum the patent US119825 by Daniel McFarland Cook also used concentric wound coils.
I have looked for that patent and in the text is referenced a circuit "D" which does not appear in the available figure. Maybe there is a missing figure where this circuit is represented. What do you think?
http://my.voyager.net/~jrrandall/CookCoil.htm
marathonman
Just thought i would add my 2 cents. have been fallowing Figueras for some time now and i have designed my own timing board that really blows PJK out of the water. what most people don't understand is that the 4017B decade counter has built in overlap capabilities. as one channel is coming down the next is coming up and so timing overlap caps are probably needed but i designed it in the board just in case. most designs on the internet have a blinking secondary output which means that there is no timing overlap what so ever in which figueras specifically said needs to happen(make before you break).  i have 9 channels because i didn't like the awfull stair step people were getting. 1-9 5 being 0 volts. the board is capable of 60 to 500 hz or more with 20 or so milliamp with 7805. it has a centel grounding pin on the IDC connector for people that want to use opto isolators and it has isolation on main power. board was made with DipTrace free and is 4"x 2.3"2 layers. 1 % metal film resisters and poly film caps all ic's cmos. the transistor are MJ11028's ran through a adjustable vitreous wound resistor  from NTE. i will post more as my build continues  and will post video on youtube soon.check out attached pic. may all of you have success
