0 Members and 87 Guests are viewing this topic.
NRamaswami
Hi:
I'm informed by Hannon that all of you thought that there should be an air gap between the South Pole of P1 and North Pole of secondary. I apologize for the air gap confusion. I fail to understand how two powerful electromagnetic cores with opposite poles can be kept apart. That will require a tremendous effort.
The air gaps I mentioned are the ones between the two plastic tubes. There is a slight air gap between the tubes. It need not be present and the whole thing can be constructed on a 5 foot or 6 foot long single tube. For ease of construction we cut the tubes. Nothing more. The presence or absence of the slight gap between the tubes is irrelevant for the function of the device.
The Figuera device as done by me is an extremely simple device. But the dimensions and the wire sizes must be kept in mind. You cannot build a cat and should not say why it does not weigh or behave like a Tiger. To make some thing to become a Tiger, you must build that like a Tiger.
You can use a 3 inch dia or 4 inch dia or 5 inch dia plastic tube and build the device. I promise you that the results will be there if you try to replicate but the size of the device and the wire gauge used and the length of the wire we used and the number of turns must all be there to see a similar performance. This will require a lot of effort and you will need a lot of labour help. It is not a one man job. But as I said the voltages are very high and the amperages are going to be high and it is deadly and you need to be careful. You must do the replication at your own risk and must take all safety precautions.
I have already filed a provisional patent application for the device disclosed and I will file a complete specification and a PCT application and then would provide step by step construction details and what are the details needed.
Whether it can become a self sustaining device I cannot say now but I can say that the device will output more watts than input watts. That much can be promised.
I again apologize for the air gaps confusion.
Regards,
Ramaswami
Newton II
Quote from: NRamaswami on February 18, 2014, 06:58:27 PM
Fix the three rods to a single base frame using clamps, bolts and nuts.  Clamps will hold the rods tightly in place. No  'tremendous effort' is required.
I think you are doing the same thing.   Seeing the cat through a magnifying glass and getting illusioned  that it is a Tiger!
NRamaswami
"I think you are doing the same thing.   Seeing the cat through a magnifying glass and getting illusioned  that it is a Tiger!"
Thanks..Regarding the bolded part.. Perform the repeatabillity of the experiment and share your results. What you think is irrelevant if you do not or would not perform experiment and share the results.
This is not a single rod to be fixed by nuts and bolts. Do you know how many rods are needed to pack a 4 inch dia plastic tube. Try packing it and then you would know the number of iron rods needed and the weight of the soft iron. So you think you would make two massive 4 inch dia soft iron electromagnets of 2 Tesla with opposite poles and they would remain in place with a clamp, nut and bolt.. At least when you think, please properly think..There is a difference between thinkers and performers.
"Whoever said that the pen is mightier than the sword, clearly has never been under any automatic fire- Gen Dougles"
Don't share your thoughts. Please do perform and share the results of your expriments. Thank you.
Newton II
Quote from: NRamaswami on February 18, 2014, 09:06:20 PM
What I said is just an example.  If it is not possible to fix the rods using clamps, you have to think of some other methods. You are talking about few rods,  I have fixed pumps and motors weighing 5 to 10 tons to base frames using power bolts and nuts. Nothing is impossible in fabrication.
Your postings clearly show that you neither have book (theoritical) knowledge nor fabrication knowledge.  You are not miscommunicating but just getting confused without knowledge.
Don't think that members of this forum are fools. They are intelligents enough to understand things without performing experiments.
Farmhand
Steel rods as a core would not be a good choice I don't think, because the ends of the cores will face each other and any loose rods will try to move when the coils are energized not just together but also they will probably try to repel as well depending of phase differences. And as well as that the rod cores will have a lot of air gaps still present.
A small gap can be maintained between cores by using paper or something in between the cores, but then that would be a paper gap and not an air gap.
Here's a suggestion to use the rods though, take one piece of tube that holds all the rods cut to length for all the cores or as many as can be got from one length of rods (bundle).
Line the inside of the pipe with a coating of oil or something like that to stop the glue sticking to the pipe (former) if you want to remove the rods bundle from the pipe that is if not let it stick.
Ok so you have a bundle of steel rods and a tube as you fill the tube with rods use some glue to glue them all together (and to the tube if desired), leave to dry so that all rods are leveled at the ends. Now you have one big core set solid inside a insulating pipe (former) that you can cut into whatever sized pieces you want without needing to cut a lot of rods. And everything is held solid in one piece. Then to prevent any movement you can use a piece of paper between the cores and use wooden blocks behind the cores to stop any repulsion vibration "movement of any significance".
Best way to cut would be with drop saw or with a "metal 'Steel' cutting disc" on a grinder, which is inherently dangerous, be careful. They make really thin ones now that cut real good but are more fragile. For safety be prepared for the disc to fracture and fly apart sending pieces at high velocity towards your chest and neck/head, if your not ready for that, then you're not ready. Suit up and full face shield.
Otherwise a hacksaw could be used or whatever.
Cheers
