Doug1
If they cores are pictured as being up and down the dotted line on the bottom used to indicate the units are stacked one on top of the other core to core then guess what the pole orientations are?Ever wonder why they are not on any core ends? I suspect the dotted line was an after thought insisted on by the examiner with the intent to avoid confusion. Ahh the road to hell is paved with good intentions. AKA free entertainment.
  Logic behind the observation. Shorter core= lower reluctance. Poor wiring diagram but one none the less. Explains the dotted lines on the bottom of the drawing and the placement of the designations N, S, A.
marathonman
Doug it could quite possibly be another coil winding as was said per Patient description. adding another additional electromagnet could also just mean another coil of wire on same core. also if another core was present would there be enough flux transmitted to the third core. ?????
So what are your thoughts on my post 947 Diagram and attached pdf ?????
Doug1
I think the first coil on the core is a split coil center tap making up the two opposing primaries and the outer one is the pick up or induced coil. Which would need a thicker wire to handle voltage and current.Not sure if all that activity could work well on a single core.The source would have to be kept very low. One could hope that what applies to dc resistance heating compared to ac would also apply in a core. Then having the fields push back and forth against each other would sort of be like a rotating or alternating field even though the electromagnets are facing same poles to each other. Power is transferred as a alternating event with very short distances of movement in ac ,the potential becomes a rigid connection between the source of movement and the end use in a mains line.Maybe the same thought can work with magnetic fields. I haven't read the pdf yet. I have some time now that the electric company drove a bush hog all over the exposed water line I was back filling.
Gonna be one of those days.
Doug1
Read it.
  You asked if the flux would be able to reach the third coil. The first coil is or the split coil if it is a split coil is longer and squat compared to the third centered over the split of the first coil. The field will expand out further then normal for the same reason a joule thief can store so much field in such a small core. Magnetic fields are pretty elastic compared to the core.It will squish out at the collision point as well as expand out in all the other directions. If it takes up a volume of space in form of a circle and you push one area flat on the circle it will have a greater pressure applied to the flat spot and expand the lower pressure surface area even further to compensate for the distortion.
  Two balloons will do if you need to see it. Or you can just use you head to picture it. Push a balloon from both sides ,where does the volume of air go? Now think back to the stack and picture it. Lots of compressed double bubbles each set being moved by its own portion of the controlled source in unison to act like a bigger version of a ac power line if you can imagine the bubbles being like mobile electrons in a single file line. Once the fields are established it may turn out you only need to make one of the  electromagnet sets alternate and the rest will have to follow with out consuming any of the source current.
  Have to go, here comes the wonder crew to fix the water line.
