Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
stprue
@allwest
That's a powerful dry cell you have created.  What did the ending voltage and ma settle at?  Any chance you could share the construction details so others could replicate?
Allwest
This cell still needs more long term testing
If you are interested in dry cells you should check my other videos on long term cells, that still have power
Best of luck
ramset
Thanks Grandma
plengo
In continuation of my research I am getting to a point where I am more and more certain I am on the correct path.
My latest cell using MnO2 + Mg + Cu + Carbon Activated + Epson salts + Distilled water is having an amazing success. Soon I will be posting more videos and results but for now let show a few weird things:
1 - when shorted the voltage and current first goes to almost zero and than climbs back to a substantial higher number (Allwest replication I think).
2 - when the cell is first make it provides (4 cells in series) 6.4v at over 100ma for a good 5 minutes and than start the normal (or more correctly abnormal process)
3 - the cell uses very little of all this chemicals , more like 90% less than before.
4 - no corrosion has been seen on the Mg or Cu or even MnO2
5 - the production of gasses is much higher on the O2 than H2
6 - it is necessary a little jump on the cell before she goes into that "special mode", otherwise she will only behave as a normal corrosion crystal cell
7 - no need for Alum and Titanium also works instead of Mg although much lower voltage and current but still works and Titanium will NOT CORRODE for sure at all.
8 - 4 cells lights 2 LEDS pretty good.
9 - As she performs better with time and dries out, no need for more water.
10 - the cell performs accordingly to the load, lower the resistance, better the performance.
All in all, I will very soon share more and ah, one more very strange thing, if I remove the negative probe of the volt meter, the voltage of the cell goes into this strange but very predictable and periodic reversal of voltage although still on both poles of the cell a normal polarity non-reversal higher voltage is shown.
Now 4 cells in series is giving 2.643v at 1.5ma very constant. Shorted it goes up and up and I have not found the end yet, because it only gets slower the growth but keeps growing.
This cell is very different and it was designed before i built with my theory being applied and worked just like my "Monkey Science" said.
The idea of using only the positive probe of the volt meter was to detect the reversal that I predicted to be necessary for it to work. Basically the cell is replenishing herself and using water and "something else" as the fuel. Water only in the beginning.
Fausto.
stprue
