Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
Feynman
I don't see too much of a problem, since it's only beta (electron) radiation.  Of course there will be attempts at suppression, but with oil north of $120 I don't really see how this argument can hold up.   Beta is the force involved in weak nuclear decay.
Also, there is no byproducts, so it's not like these reactions have waste. They are simply reversible weak decay which tap vacuum energy.   That is, the excitation causes a proton/electron pair to convert to a neutron + neutrino (generating a new element for a split second), then the element decays releasing electron radiation (it's neutron changes back to a proton while emitting highly energetic electron and antineutrino). This reversible conversion is what releases the vast amount of vacuum energy in the form of beta radiation (fast electrons).  I think it's pretty safe, although it's probably a good idea to construct experiments using some beta shielding.
I also saw the other elements , but I am wondering how you can possibly apply a B-field to a gas. Helium or nitrogen seem good candidates because they are both inert. The main problem with a gas is heating from the beta decays, which would cause it to expand against the walls of it's container, generating pressure.
For now I think carbon is probably the best route forward, but the trick will be creating a spark gap which can fire many times per second without degenerating the carbon nor the tungsten.
starcruiser
Anyone have a comment on device #2????
Seems this would be a better way forward and would reduce the require starting voltage and might even allow a self running mode by using feedback.
.5T is easily created by either a electromagnet (as stated) or a small stack of Ceramic magnets or a small Neo.
easy enough to build a small 21Mhz osc using a blocking or similar design oscillator. Then power a resistive load and see what you get. Could even charge a few capacitors to even out the flow.
Thoughts?
Regards,
Carl
Feynman
I have talked to Juan and he said the 21Mhz NMR oscillation is possible, but he is not actively persuing it.
He has built self-powering units using the standard technique (discharge energy into B-field biased carbon/tungsten, collect beta electrons with toroid).  His devices do not appear to have many capacitors, so I think he must be using one unit to trigger the pulse in another unit and vice versa.
Here is a picture of his 60kW carbon-fusion device
THESE ARE OU.  GET THE PARTS.
Feynman
This is the schematic for JLN's experimental carbon-fusion setup.
aleks
Quote from: Feynman on May 02, 2008, 01:28:46 PM
Can the rods be enclosed into some kind of high-resistive foil or just plastic?
