Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
Feynman
Thanks Abba.  I agree we must keep experimenting.  Maybe the beta electrons are in KeV so they don't show up on higher quality detectors.
I might add EE Commander 'Groundloop' thinks this is an EMF process.  He also suggests photo paper for definitive resolution. I guess we should all place our beta, I mean, our 'bets' now.     We can trade beers at the first International Overunity Conference.  ;D  ;)
Feynman: low-energy beta process , K-capture
Abba: must be nuclear effect, beta process
Koen: Beta capture, Protelf
R: beta Scattering, K-capture
Groundloop: powerful magnetic pulse ("EMF")
Juan: Boron-12 Beta Decay
Naudin: Boron-12 Beta Decay catalyzed by X-rays and 'spark gap'
UncleFester: Beta, K-capture, but does not care what it is as long as it powers his house.
Jon: Rotating magnetic field
Frank: Beta
aleks: Magnetic field amplification / field-free electron acceleration
zerotensor: Current-induced beta emission in magnetically-biased bulk graphite arising from cooper-pair-bisoliton recombination at graphene nanocrystal boundaries
@DrStiffler
In addition to rod crystal structure, R thinks maybe the beta electrons are KeV and are being filtered by the 'low pass' filter on your detection equipment.  In his words...
QuoteR:
It'll have a bandpass filter
essentially
low energy particles won't even make it to the detector
they'll get deflected to the fricking  wall before they get detected
i.e. turned through the magnetic field
So I guess we will see what's up here.  I think photo paper might be a better way to check than beta detectors, especially if these are low energy particles and we are also producing bursts of EMI along with beta... I guess our little beta rays just need to be more energetic than ionization potential of silver iodide or silver bromide... which is very low.   So photo paper will tell us the truth.  Is this beta or magnetic?
Mitsuo Kawasaki, Yoshihiko Tsujimura, and Hiroshi Hada
Department of Industrial Chemistry, Faculty of Engineering, Kyoto University, Yoshida, Kyoto 606, Japan
Received 11 June 1986
Photoionization thresholds of small photolytic silver clusters (Ag2, Ag3, and Ag4) formed on silver bromide grain surfaces were evaluated from the threshold photon energy required for inducing the photobleach of the clusters. Threshold energies needed were about 1.6, 0.75, and 1.1 eV for Ag2, Ag3, and Ag4, respectively, showing an obvious even-odd oscillatory trend of the ionization threshold. The oscillation, however, seemed to be smaller than that expected for isolated metal-atom clusters, indicating the importance of interaction with the silver bromide grain surface.
callanan
Hi All,
Don't have much time but I need to say some things about this very important thread, topic and device/process. So I will be brief and in point form.
- For those looking at taking the effect further, don't question the reaction and production of beta particles as this has been experimentally proven. Then, don't look at how you can capture and convert these particles to usable energy as this is well documented in the art of atomic batteries. The carbon rod by itself does a far better job of converting the beta energy and adding it to the energy used to cause the reaction in it.
- Once the reaction is initiated by the input pulse the beta energy will get reabsorbed and converted into electrical energy that is added to the input pulse which will result in a stronger magnetic field around the carbon rod than for the initial energy of the input pulse.
- The magnetic field around the carbon rod can then be tapped by a soft iron core around it which also may have a coil of wire wound around it, hence it will be a toroid coil with an iron core within. The carbon rod placed in the hole of the toroid will effectively act like a half turn winding and induce it's energy into the toroid coil and the turns ratio will by high. It will be effectively be 0.5 to the number of turns in the toriod coil. So the step up in voltage will be very high and will cause a reduction in current but the amount of current in the carbon rod including the additional beta energy will be very high and in the thousands of amps so the current power factor translation is not an issue.
- The polarising magnetic field required to initiate the reaction in the carbon rod does not need to be provided by magnets or by a seperate DC supply via a coil wound directly on or across the carbon rod. Another heavy and thick wire coil of a few turns can be wound and placed within the iron core of the toroid coil/transformer such that it is perpendicular to the toroidal windings. The magnetic field of this coil will be in parallel to the axis and length of the carbon rod.
- The toroidal transformer will now take the form of a normal short, thick winding solenoid coil (polarising coil) which is then covered with a soft iron core upon which a toroidal coil is wound (output coil). The carbon rod is then placed in the centre of the toroidal transformer and connected in series with the polarising coil. When a heavy current electrical pulse is sent through the polarising coil and carbon rod, which is in series, the strength of the polarising coil's field is increased when the beta reaction energy is added to it which further increases the beta reaction in a self feeding mode. A very high current diode can be also placed across the input such that it will keep the additional energy created in the series loop flowing back into itself. The total energy flowing through the carbon rod will then be induced into the toroid output coil via the iron core with a turns ratio of 0.5 to X, X being the number of turns in the toroid coil.
This is a simple and straight forward understanding of how and what you can do with this device. But I must say that the basic physical embodiment of such a transformer has previously been described by Stan Deyo in his books, "Cosmic Conspiracy" and "Vindicator Scrolls", and videos. In these books and videos, Stan Deyo describes that such a constructed toroidal transformer has been used in advanced magnetic propulsion systems in top secret government projects. His knowledge of this, he claims, stems from his past employment and contacts in the CIA and then later private advanced research companies he worked for.
Regards,
Os
AbbaRue
An important question about firing the capacitor bank through a bank of MOSFETS:
Once the MOSFETS are turned on how do you turn them off again.
Does someone have a good schematic diagram of how the MOSFETS should be fired
to get a short pulse and then turn them off again.
I find this would be important for self running.
Don't want the output fed back through the MOSFETS.
Feynman
@AbbaRue
I usually use MOSFET driver or build one.  You can get cheap mosfet drivers from digikey, or you can make 'em with an NPN and PNP transistor.  You gotta drive mosfet gate to current saturation otherwise it acts all funny. You can , however, try to directly drive your  say square wave into the mosfet gate, but the rise/fall time might be slow.  Connect mosfet source to ground, and connect mosfet drain to (+)...first through your load followed by a current limiting resistor then to (+).
@callanan
Fantastic info, Thanks!
Inventor81
.5V
300A
Plasma.
These numbers do not equate to the same sort of energies in a solid conductor.
300A refers to the amount of charge circulating past a certain point in the plasma.
.5 V is likely the net kinetic energy of the plasma.
Electrons in the non equilibrium plasma would cause all sorts of effects, especially given THE STRONG MAGNETIC FIELD OF THE TORUS.
Also, the interesting thing to note is that
THE CARBON WAS THE TOROID...
Since it was the shielding of the tokamak.
