Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
Kator01
Hi speedy23,
I know this one. No, the valle-stuff is something total different.
Kator01
kewlhead
Howdy Kator01,
Do you mind to answer a few questions about that valle stuff?
Koen1
So what happened to this thread, did it die or what?
-bump!- ;D
Quote from: Kator01 on October 14, 2006, 11:23:04 AM
Well then please explain what is so totally different about it?
It does seem remarkably similar to the Valle synergetic process as
described on Jean Naudins website.
... untill I hear what is supposed to be so totally different about it,
I'm going to assume it is the same thing.
After all, they are both tallking about pumping several KeV into
a Carbon rod, having something happen, and getting several MeV
out of the rod again.
And they are also both talking about the C turning into a B isotope,
which decays back into C again while releasing excess energy.
Sounds crazy, but also very similar. :D
UncleFester
Vallee generator IS the same. I have built the generator and it does the same thing as this gentleman is talking about. It works between many different elements, not just carbon.
It is also the same thing that Edwin Gray found, the gain in his Cset. No one I know of has put these facts together, but it is clear that all are related. Even if you set it up the circuit differently, the result is the same. You end up with a large pulse of high energy in the kilowatt range. This even works without the B-field, but only fractions of the result with the B-field.
Tad
exnihiloest
Quote from: UncleFester on May 01, 2008, 01:39:43 AM
Vallee generator IS the same...
Right. In this paper (in french):
http://franckvallee.free.fr/localhost/plain/content/download/137/535/file/Science%20&%20vie.PDF
it is said page 3:
"with an efficiency of 10-5 (reaction of 1 atom on 100,000) and a global performance of 20% the replenishment of 12C from 12B disintegration gives 8 KW per gram".
A similar setup to this from Tesla_2006 is showed page 4. It is said that OU appears only when the current in the coil around the carbon rod, provided through the "rh?ostat", is above a certain threshold. Then the output current is 4 times that given by the capacitor discharge. Tesla_2006's setup seems to be a plagiarism.
