Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
BEP
@Koen1
In your research, have you located any construction details of the smaller betatrons used in the late seventies? These would be the ones with the hollow porcelain toroid. They varied in size but some were as small as a couple of inches in diameter.
I'm very interested in the fins (they looked like coils and also may have been used for acceleration).
Koen1
Quote from: BEP on October 15, 2008, 07:39:50 AM
@Koen1
To be honest, I have had serious trouble digging up good pictures of betatrons from the old days, and I am not certain which type you are referring to,
exactly. Most pictures of betatrons I know are fairly large ones with several variations of coils, and as far as I know they started using porcelain for
the vacuum chamber as early as the 1940s (very shortly after the betatron had first been dreamed up) so that doesn't mean much...
But I have not seen many that are very small, I've seen one or two intended for portable X-ray machines from the '70s, but those all showed
big chunks of iron core and none of them were "coreless", nor could I see much of the coils on those pictures.
If you have a link to some pictures of the exact type you are talking about, I may be able to give some usefull info.
QuoteI'm very interested in the fins (they looked like coils and also may have been used for acceleration).
Well, like I said, I don't have a mental picture of what you call "the fins" so I can't give you any clear info on that at the moment,
but if you could provide a picture I'm sure I can give you some more info.
I can tell you that most betatrons do not have anything that looks like "fins". There's versions that have rings of core material
wrapped around the toroid, with coils wrapped around those rings again, there's versions that use pancake coils, and there's
versions that use one or more linear coils, and those again can be coreless or cored. And all of them are used to achieve
accelleration. After all, basically the thing is nothing more than a very large transformer where the input coils are the primary
and the toroidal vacuum tube is the secondary coil.
sparks
   I believe Moray employed a radioactive coating to build a cold plasma.  The radioactive coating controls the formation of a predictable plasma lattice.  The electron migration about the neucleic lattice now going from a distance measured in proton radians to millimeters.  The electrons are now moving at near the speed of light over greatly extended fields.  Their angular momentum energy no longer resulting in electron pairing and being expressed on the external field as high frequency em waves.  These waves then mixing with the emwaves from the radioactive substance.  This mix resulting in a predictable plasma construct and selfproduced electrical current.  The plasma current then coupled to an external circuit.
   Tesla exploited plasma construction in his spark gap and latter in partially evacuated tubes which were coupled to electrical circuits.  This energy that is being exploited is the intrinsic electron kinetic energy normally expressed in atomic orbitals and electron angular momentum!
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
forest
Quote from: sparks on October 15, 2008, 08:45:03 AM
I heard about magnetic field lines frozen into plasma. Something tells me that it may be together with magnetic reconnection an explanation for radiant energy and particularly for Edwin Gray conversion switching tube, which looks similarly to Protelf in case of carbon rod usage.
Look here : http://en.wikipedia.org/wiki/Magnetic_reconnection and imagine what would happen if plasma which has an electron fast flow current inside and frozen magnetic field was abruptly stopped/removed just after reconnection took place.I see this reconnection as shown on picture like a implosion of magnetic field lines where some of them are reorientated.I assume that on removing plasma external magnetic field  tend to revert changes like a bowstring usually do.It may produce huge magnetic flux , maybe even propagated as longitudinal wave.
It a good sign that scientists start to talk about such processed, which are clearly a source of "free" energy (energy taken from magnetic field of Earth ,Sun and solar wind).
Quote :
"AKR is similar to radio emissions that emanate from other magnetospheres at Jupiter, Saturn, Uranus and Neptune but also certain solar and stellar radio bursts. The radio emission is a result of a plasma instability that frequently develops in astrophysical magnetospheres which can efficiently convert free energy present in energetic particles into radiating electromagnetic waves. Its full comprehension is therefore of crucial importance", wrote Philippe Louarn (CNRS, Toulouse, France) in a recent review on the subject. "
Source : http://clusterlaunch.esa.int/science-e/www/object/index.cfm?fobjectid=43018
I suggest this as a basic source of radiant energy as depicted here : http://clusterlaunch.esa.int/science-e/www/object/index.cfm?fobjectid=40762 and described here http://clusterlaunch.esa.int/science-e/www/object/index.cfm?fobjectid=42863
IMHO, take plasma rich of electron unidirectional (!) current (as fast as possible ,probably near light velocity) in magnetic field, create such plasma and destroy at high frequency . When abruptly stopped/removed magnetic reconnection reversion will release radiant longitudinal wave. Collect energy as a large current when radiant energy is passing through copper or as a magnetic field when it's passing through iron.Surely both copper and iron must be placed in correct direction and correct distance from source.
forest
Quote:
"The whistlers were found to be greatly enhanced when reconnection kicked off (Figure 2). In addition, as reconnection proceeded, the wave frequency became higher and higher. The fact that spectral characteristics of the whistler waves are observed to be different before and after the start of reconnection suggests that they were produced by different mechanisms.
"The data collected by the four Cluster satellites on 21 August 2002 suggest that whistler waves prior to reconnection may play an important role in triggering reconnection", says Dr. Jinbin Cao, corresponding author of this study published in the Journal of Geophysical Research."
Forgive me but I have a feeling that it's the same what Tesla saw performing pancake coil experiments Voltage stepped  up in strange ratio when radiant energy was flowing around coil turns like whistler wave frequency ...
