TK device, TPU.. Only enter if you seek truth. Cause here it is...
Started by elementSix, December 14, 2012, 07:26:31 PM
AlienGrey
Quote from: Zeitmaschine on October 20, 2016, 04:30:04 PM
Then the original Don Smith device does work or does not work? In the 1996 presentation it looks like it does work (somehow).
Let me guess: The white round capacitor tunes the secondary coil to twice the frequency of the primary coil (red). But that frequency is floating (not phase-locked to the primary circuit) hence it takes a while till it warms up and reaches the correct value, thus the output voltage goes up slowly during the presentation. That implies that the Kapanadze device is more sophisticated because here the two frequencies are automatically in phase (thanks to a diode bridge frequency doubler).
No none of that ! is correct at all! sorry.
Zeitmaschine
Quote from: elementSix on October 20, 2016, 08:05:49 PM
That Don Smith device is copied exactly.  Which tells me that it doesn't work.   Don Smith himself said that it doesn't work as displayed,   because it was the only way he could do what he does without reprocussions.
Hmmm .... it didn't work during the presentation? Then why no one complains about that at the presentation? They all look satisfied with that show.
Quote from: Sequental.9 on October 20, 2016, 08:21:34 PM
you just need a variac of that size current step it up with geometric resonance and drop it back down via a step down transformer to ground !
What is »geometric resonance«? ???
OK. But isn't step up and step down exactly what I have described here: Re: New April 2016 Video from Kapanadze shows again KWatts of Free Energy ??
Quote from: AlienGrey on October 20, 2016, 09:45:35 PM
How do you know for sure? You know the basic operation principle of the device so you can safely rule out all incorrect concepts? Interesting!
scratchrobot
Quote from: Sequental.9 on October 21, 2016, 06:47:47 AM
Geometric resonance for a circle is 360hz equal to 360 degrees ! Its that simple ! This is mainly derived from phonon activity and is often dependent on the right elements like copper and iron as they resonate with each other but copper to copper also resonates with its self !
You need also to add in other energy factors like negative resistance and the stark effect with protons and paramagnetic peaks set up by bosons !
High frequency also needs to be dropped down to low frequency buy pulse action chopping up the gain in the high frequency ! You do that with the spark ! RF is then sent through the system and the electrons if permitted by negative resistance will accelerate close to the speed of light gaining more mass !
Its this combined set of actions that can set up an avalanche of free electrons into the load ! Their are many ways you can set these thing up as an OU system .......
Also double negative connections are often used on the output transformers to increase field density resulting in a rise in the harmonics prior to the load ! Back EMF helps the system to compress electrons where they expand outwards when inside the load !
I don't designe like the way the KP units is as they can be a bit of a health hazard ! RF at 600v and above with compressed pulse high frequency can kill brain cells or even short out the neuro networks ! If that is ok with you then build the KP or other paramagnetic units ! But please inform your local neighbourhood  of the pending dangers for your new free energy technology from Russia ! They will need to wear a metal hat hahaha ...
Why do you think these things are not for sale ??? ? Are you sure you want one ??? Their is a much better option like the safer one hahah
S9
I thought you wouldn't post anymore because of cyber attacks?
Talking about Geometric resonance, phonon? activity, protons, bosons, dark matter..etc.  :o
You went to the same university like Gerard Moron and Bob?
https://www.youtube.com/watch?v=Ydvic9aG5BE
You should use their bulb so you can watch the electron flow get converted to dark energy at the speed of light.
Or are you a 12 year old?
Why do you think these things are not for sale?
What a pile of bullshit you are posting here... it's that simple.
(Read 94603 times)  :-[
conradelektro
Quote from: Sequental.9 on October 21, 2016, 01:29:20 PM
Nut you can now buy a mega watt free energy generator from me !
Let me levitate you and place you over the middle of the pacific ocean !
If you wish to challenge me then do so with some real data !
It would be very helpful if you supported your claims with real data. So, challenge the unbelievers with real data, please!
If you can not provide real data, please be quiet, nobody needs aggressive words. And remember, the one who makes the outrageous claim has to provide proof.
Look at this web site, it explains very clearly why you have to provide proof:
http://www.qcc.cuny.edu/socialsciences/ppecorino/phil_of_religion_text/CHAPTER_5_ARGUMENTS_EXPERIENCE/Burden-of-Proof.htm
https://youtu.be/KayBys8gaJY (if you prefer to watch a video explaining the burden of proof)
Greetings, Conrad
conradelektro
S9, thank you for your answer.
Whatever I could say in response would not be helpful, therefore I shut up.
Greetings, Conrad
