Lenz Forceless Generator
Started by vineet_kiran, March 07, 2013, 11:55:52 PM
Bruce_TPU
Quote from: vineet_kiran on March 07, 2013, 11:55:52 PM
A try to eliminate Lenz's forces.
Whenever you place North and South face of magnets on opposing sides of coil, you end up with very LITTLE amount of power.  Flux cancels and no power is generated.  I don't believe it will work, sorry, but would encourage you to try, as that is how we learn.
Cheers,
Bruce
crazycut06
I believe that this setup is an ecklin brown flux gate generator, which is said that when the generator is loaded the rotor speeds up making it a lenzless generator....
crazycut06
Quote from: Neo-X on March 08, 2013, 03:47:08 AM
That was similar to daniel quale generator. Even though it has less lenz effect in my understanding this setup doesnt produce so much flux change as a result the induced voltage is not so great.
His setup does not produce much power because he used ferrite speaker magnets, if neo mags are used it is posible to get more...
vineet_kiran
Quote from: Bruce_TPU on March 08, 2013, 01:38:50 PM
In that case none of the generators in this world should work.   Because in all generators north and south poles are shorted through the coil.  When polarity is reversed it produces AC wave in the coil.  Open a generator and see.
Bruce_TPU
Quote from: vineet_kiran on March 08, 2013, 06:44:40 PM
You really must play with magnets and coils more.  To produce "electricity" of ANY amount, the coil must see a change of flux.  EXCEPT in the case of a unipolar generator which is an entirely other subject.
If you take a north magnet above a coil, and a south facing coil below the identical coil, and pass the coil through, the way that you have drawn the coil, having a magnet on either end, it will not work.  I have tried it in real life many ways, and the flux cancels, the coils sees no change of flux or very LITTLE and LITTLE power is produced.  Please, feel free to try, if you still do not believe me.  I would love to find a way to do that and be proven incorrect.   ;)
Cheers,
Bruce
