Magnet coil cores, demagnetization power and Lenz delay.
Started by synchro1, June 09, 2013, 11:07:49 AM
MarkE
Synchro1 the video demonstrates:
Any magnet of any orientation attracts / is attracted to a soft magnetic piece.
Magnet poles of the same polarity repel.
Magnet force is very nonlinear.
Forces add.
None of these facts contribute to the wrong idea that there is a "delayed Lenz effect".  And none of these facts contribute to the wrong idea that by arranging magnets and / or soft magnetic pieces that there is extra energy to be had.
tinman
There is always a delay in the lenze force,as a magnetic field dose have a speed limit-although the delay would be that small,it is almost unmeasurable.This also means that there is also the same delay time in the motor/generator effect,so the net result remains at 0.You can however use the lenz force to increase motor torque and generator output.
Motors and generators are simply being designed wrong.
It is extreemly simple to design a motor that increases with torque when a load is applied to the generator coil's,and reducing the P/in to the motor at the same time-->this i have shown many times. ;)
synchro1
@Tinman,
You contradict youself. Tk maintains the rotor will slow down and stop. You people contnually ignore the fact that Konzen's rotor is speeding up. I've been describing the run away effect for years over countless threads. You people act like I'm a trying to perpetrate a hoax. Why don't you try it?
synchro1
Quote from: MarkE on December 13, 2014, 06:05:00 PM
Forces add.
What's that supposed to mean that "Lenz Delay Effect" is a wrong idea? Did you watch the Doug Konzen coil shorting video? How do you explain the rotor accleration coupled with the drop in input that Doug demonstrates?
MarkE
Quote from: synchro1 on December 13, 2014, 08:48:35 PM
It is a wrong idea because:
1) Lenz's Law states only the direction of induced currents.
2) The induced currents have not been showed to be delayed.  It is in fact the immediate induction of eddy currents that delays build-up of net magnetic fields and resulting force.
