Tragic accident with ball magnet EMDR motor-generator
Started by hartiberlin, June 22, 2013, 03:08:34 PM
synchro1
Quote from: MileHigh on June 26, 2013, 06:48:34 PM
I think the real lesson in this tragedy is to ask yourself why.   Why did they try to spin up the ball to super high speed?  Was there a reason for doing that?  I doubt that there was.  People make these things and then try to push up the speed for pure sport, there is no real reason related to research.  It's the equivalent of a child playing with matches.  Hopefully others will learn from this.
Synchro1:
That's just fantasy talk like usual.  Lots of talk but not much in terms of tests and results.   If you believe what you are saying then present some data to back up your claims.
You're the guy who maintained Tesla's bifilar coil for electromagnets was void of any actual function. Lorentz maintains current's effected by magnetic field and visa versa. It takes power to magnetize and power's generated when material's demagnetized. That includes the Neodydmium metal the magnet's made from. We can see power come from decoupling in the Leedskalnin experiment after 2 years by RWG. Power's generated directly from the magnet the same way, at much higher frequencies! REG's video:
http://www.youtube.com/watch?v=832qz3s1M-s
Synchro1:
I posted a question asking for someone to suggest an application for Tesla's "series bifilar" coil acting as a self-resonator and nobody had an answer.  Are you trying to imply that I am wrong with the sentence, "You're the guy who maintained Tesla's bifilar coil for electromagnets was void of any actual function."  If yes, what did I say that you think was wrong?
QuoteWe can see power come from decoupling in the Leedskalnin experiment after 2 years by RWG. Power's generated directly from the magnet the same way, at much higher frequencies!
You seem to be drawing a connection to the Leedskalnin experiment and the spinning ball magnet in a pulse motor.  There is no connection beyond the fact that changing magnetic flux passing through a loop of wire can result in power output if you connect a load across the ends of the wire.
Honestly, the "Leedskalnin experiment" is one of those funny things that takes on a life of its own on the forms.  This is a topic that might be covered in 20 minutes in a grade 8 physics class and then the class would move on and then nobody would give it a second thought.  Somehow Mr. Leedskalnin got his name associated with this and he somehow seems to have claimed ownership of it.  The problem is that many of the experimenters that play with the effect and make video clips, etc, can't actually explain exactly what is going on whereas a 13-year-old keener in grade 8 physics class could.  It's just one of those strange things in life.
Your comments about the sphere turning into a power plant or this earlier comment, "While it's behaving that way in tight resonant oscillation, there's no further draw on the power source" are simply wrong.  It's just fantasy talk Synchro1.
gauschor
So is there overunity with this spinning magnetball device or not?
synchro1
Pirate Twinbeard measured 253 amps from his output coil spinning a 1/8" neo sphere super sonic, enough current to fry all his circuitry. Could this be cold electricity? The Micro Cosmic plenum may reach absolute zero like the Macro one in outer space. Current drawn from there may be chilled down some. Have you seen his videos?
Go Speedracer! FlowerPower Frequency - YouTube
Groundloop
Quote from: synchro1 on June 28, 2013, 01:43:46 PM
synchro1,
How did he measure 253 amps?
What was the thickness of the wire used in the output coil?
At what voltage did he measure 253 amps?
What load did he have on the output coil while measuring 253 amps?
GL.
