Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
vrand
Quote from: totoalas on October 08, 2013, 11:08:40 AM
Yes on the loop only .... never measured on the light bub yet   but the loop cable surely will melt with this current just like touching a hot iron
Any special ground designs used? Barbosa also had an aerial patent design that did not need a ground connection?
totoalas
Quote from: vrand on October 08, 2013, 11:51:07 AM
Output current measured on the bulb is 0.3 Amps
The loop cable temperature rise from 25 to 70 deg C at the termination point of the end loop cable in 5 minutes which melted the plastic in the terminal block
The reason for the heat at the termination end of the loop is it must pass to a coil to absorb the heat and not to a 2 turn coil I made   ...  Carlos used the third coil to close the loop....   mine used the two turn coil from same wire loop
The earth ground is another circuit   thats another test
from my tests   we just need to put the right size of third transformer  for ex   1 kw for air conditioning   never tried it yet
vrand
Quote from: totoalas on October 08, 2013, 12:31:19 PM
Is your setup with 2 transformers, or 3 like Carlos?  If 2 do you plan on trying out with 3 transformers?
totoalas
my set up used 3 transformers with the third   as output tothe 60 watts lamp
Carlos has confirmed the set up and in the right direction and explore
vrand
Quote from: totoalas on October 08, 2013, 12:59:52 PM
Okay, thank you for the description. Please post a photo or video when you get a chance, as a picture is worth a thousand words  :)
