Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
a.king21
Clarence: Sorry to hear about your equipment. Lots of us are quietly keeping an eye on this thread and hope you succeed.
skribat
hi guys .. Spanish isn't my language ( a little Spanish and basic French)  but this looks VERY interesting, was sent to me by a friend in Brazil .. all you Spanish speakers this is your chance to shine .. good luck with the translation .. skribat
https://www.youtube.com/watch?feature=player_detailpage&v=lUtRFSqj504
Clarence
Quote from: a.king21 on January 29, 2015, 04:44:21 PM
Clarence:
Hello a.king21, void, & ALL,
the weather here has NOT been favorable at all  to finishing the wire connections to the ground rods and sealing the connections
(since they had to be below the surface by about 4 inches and could not be protruding above ground level at all- property
owners demands). I deemed the moisture sealing of connections and keeping dirt, etc. completely away from bare wire and clamps
as necessary to ensure no type of resistance sources between earth - rod - wire - and device. I want to keep everything clean and
unhampered to give a reliable result to the outcome of this revised GROUND ROD RETURN SYSTEM.
I have the background of the previous TWO rod system results at 84v to 90v to compare results against.
my new Tripp Lite PR 30 is in and in place ready to go ( hooked to mains supply this time until I determine that it IS or IS NOT safe to
to include it in the system.
I thought it was humorous about me getting a farmhand to help me put the rods in the ground!
This is a 64 acre farm alright but the ONLY FARMHAND HERE IS M E E E!!!
meanwhile back at the farm - working on getting it done, the weather clearing hopefully ( Louisiana is a little swampy!) .
Will give new info as it happens.
Thanks , cheers!
Clarence
Void
Hi Clarence. Thanks for the update. Ok on you being the only farmhand. ;)
Take your time mate. Rushing at this sort of stuff does not help anything.
If it is kind of swampy out in your neck of the woods then that may mean that
you should have quite good potential conditions for getting a really good earth ground.
All the best...
Bob Smith
Quote from: skribat on February 03, 2015, 04:02:50 PM
Skribat, nice find!
Only had time to watch the first video (over lunch at work).
He's basically saying that the B&L schematic people have been working with are not producing the desired effects. He then shows another schematic that doesn't produce the effect either. Then, he shows one that does seem to produce abundant amps from the ground, starting around 7:20.
Here's what he says at 18:15:
"I believe B&L haven't told us the whole truth. If we input direct current without this capacitor (see right side of diagram), there is no substantial raising of current. To capture the electrons from the ground, there needs to be a means that permits, by induction, for them to be generated. And this instrument (means of induction) is still the capacitor, one of the great protagonists of electricity and electronics."
Note, the negative input remains hanging or "in the air" as he says.  He's showing 115V, 0.0-1.0A in, and at each winding of his transformer, he's getting around 168 amps.  That's a lot of juice. The mains amperage draw continues to be around 1A even as he's running lights and some other gizmo (didn't catch what it was) off the output. It would seem the extra electrical charge is coming from the ground.
Looks like pretty impressive results.
I wonder how we could scale that back to a simpler level.
Looking at his schematic, I see an open system (with open neg lead), and with the capacitor, I'm reminded of Tesla's apparatus for collecting radiant energy.
Hope this helps.
Back to work Bob.
