Thanks to ALL for your help!!
1500% energy out!
Started by ingyenenergiagep, August 27, 2013, 03:01:18 PM
                                                  FE:Q.& A.
                                                 room heater
                                      like this here with candle
                                       or with bulb GlowWarm
                                   http://www.heatstick.com/
                                  similar with technical details
with 1 bulb           only 400W/ 60sqm( estimated= semi-detached house)
                              externally 0°C and 14,5°C inside :night ambient
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=19&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881019&CC=GB&NR=2203529A&KC=A
with special heater elements     average less 50%
http://www.canlaser.com/en/Home.aspx HTM
http://www.al-bernstein.cc/new.html heat resistor
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=20030424&CC=US&NR=2003077078A1&KC=A1 up to -75% savings
http://www.average.com.ua/presentation.pdf
http://www.humanitad.org/team/145/
with an energy limiter    like the "driver" above:
                                       up to 90% savings by ultra on/off periods
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920714&CC=US&NR=5130608A&KC=A  Dirac spikes/surges
and here
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=20090813&CC=DE&NR=202008014201U1&KC=U1
(= http://www.graphitherm.eu/steuereinheit.html )
with more bulbs/elements    600W for 11.000BTU (X 0,293= W)
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19890823&CC=EP&NR=0328893A1&KC=A1
series connection from resistors(=heat elements / bulbs)
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20041118&CC=WO&NR=2004100349A1&KC=A1
but with attention VA input and lumen-heat/W output
[size=78%]http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=6&adjacent=true&locale=en_EP&FT=D&date=19821029&CC=FR&NR=2504768A2&KC=A2[/size]
for example: 75 (220V)bulbs a 15W in serie energized with 110V give 75 x5Watt consume with an heat output similar a 1500W radiant heater
I am also in search of an excellent heating system ;)
Sincerely
              CdL
p.s.:  to #8: 1KWH bat (tery) gives 4-5KWH  ?? Under which condition ?
                        or meaning     gives 4-5KW
ingyenenergiagep
"(#)   Sipyke válasza Atis57 hozzászólására (»)   Jan 28, 2008
Jól van. Az úgy kezdődött, hogy kaptam vasazós romáktól egy szörnyen rossz állapotban lévő akksit. Még fel lehetett tölteni, kísérletre jó volt. Megláttam a neten Tesla gépét, szóltam egy haveromnak is, aki szintén érdeklődik hasonló dolgok iránt. Elkezdtük nézegetni, mit csinálhat valójában a kapcsolás. Mivel több ingyenenergiás gép rajzát letöltöttem, megegyeztünk, hogy ki melyiket próbálja ki. Másnap hívott, hogy ez működik: Az ő akksiját töltővel nem lehetett feltölteni. Amikor ezt rátette (persze akkor még csak relés próbaverzió volt) 12,8 V-ra felemelkedett az akksi feszültsége. Megterveztük a saját elektronikus verziónkat paneltervvel, és meg is építettünk 1-1 db-ot. Én teszteltem. A rossz 44 Ah-s akksit 10 órán át 4,5 A-al töltöttem,15 V volt közben a feszültség. Ez kiszámolva 675 W energia. Ezután egy 6V/30 W vetítő izzóval elindítottam a tesztet. 97 órán át működött megállás nélkül,az izzó feszültsége 5,9 V és 6,3 V között változott, Az árama pedig kezdetben 5,6 A, majd lecsökkent 4,8A-re a legvégére. Akkor azonban az akku kapocsfeszültsége a 11 V-ot sem érte el. Látható, hogy az izzó teljesítménye szinte végig 30-35 W között volt, csak a legvégén ment ez alá. Ha 30W-tal számolunk, akkor 2910W-ot vettem ki belőle. Ez a gyengébb akkuval vitt teszt volt. Csináltunk még egyet egy jobb akksival,de arról sajnos nem tudok ilyen pontos adatokat adni. Na nem azért mert nem akarok..."
E In: 10h 15V 4,5A=675Wh
E Out: bulb, 97h 6,3-5,9V 5,6-4,8A. 5,9V and 4,8A with 97h=2747,04Wh.
                     Thank you for the fast #8-repeat
    after the translation from this hungarian article I understand your hope
           2747W out and 675W in :o , YES,it smells like OU 8)
                 especially approved by a 97h teste
                 Where can I get this kind of battery  ;D
        OU-question ist the lumen/W -quantity during this 97h experiment
Up today I only had the knowledge of this battery feedback-circuit
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=20090326&CC=US&NR=2009079393A1&KC=A1
I thank you for the sharing of really interesting details about this dimming potential from heat energy and the surprising "generating" battery !
Sincerely
              CdL
1500% : at first ridiculous  ;D !
second moment: Gibbs FE potential  8)
          thinking about
a. Lazlo Gabor "series" of capacitors
b. http://en.wikipedia.org/wiki/Surface_plasmon_resonance
c. thermonuclear pulsation behaviour :EMp1 + EMp2
http://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=3706385A1&KC=A1&FT=D&ND=3&date=19880908&DB=EPODOC&locale=en_EP
d. inductive + capacitive resistance
e. high/er frequency : magnetron ( t.a.s.e.r. and m.a.s.e.r.)
f.  Tesla bifiliar coil
MenofFather
Quote from: ingyenenergiagep on August 28, 2013, 08:28:35 AM
Impulse load, 1A on batt (100Hz-40kHz): smaller sulfate crystals, less sulfation, more battery cyle, longer battery life?
No. Basicly.
