I need help to get this EV GRAY type system to work
Started by ranuhook, September 30, 2013, 11:43:24 AM
ranuhook
Quote from: lzbin80 on October 02, 2013, 04:54:36 AM
From what I've heard, Some free energy generator produce very high voltage from only 12V, think of 3000V or more.
I recommend put multiple 1N4007 in series(3-5), and PVC wire protect all the wires and insulator type wrap all the connections.
thank you all for your support.
1. i am coming from the fact that i read somewhere that the setup will give (12v + 60v) x (60amp + 0.5amp) [battery and transformer voltage and amp summed up to give 4356VA.
2. based on 1 above, and from the fact that i also read somewhere that if the voltage on a battery does not fall, amperage is not consumed, the circuit shown was designed, just by following the E V Gray section for getting the high voltage.
3. with 1, and 2 above, i got a high voltage going into the inverter, but the control is now my problem.
(a) without the control, diodes blow up
(b) without the control, it is likely the inverter too may blow up, since voltage going into the inverter will be too high.
4. so what i need is the help to control point 3 above (since i have confirmed points 1 and 2, and find them to be ok with me)
thank you all
ranuhook
Quote from: e2matrix on October 03, 2013, 01:43:01 PM
Do you really intend for the diode to be facing the direction you have shown in the schematic?   It looks backwards depending on what is it's intended purpose.
as for the diode diagram direction, i think it is to allow the electrons flow towards the positive pole of the battery, please correct me if i am wrong.
ranuhook
i am still waiting for directional help and support. thank you all
lifeforce-energy
Hi Folks,
I have not posted for a while, but have been spurred a bit more into action with the rising costs of domestic utility energy - namely electricity and gas!
How Ed Gray's system work's has already been given in Dr. Peter Lindemann's book called "The Free Energy Secrets of Cold Electricity" which is available mainly now as .pdf copies
from the web, as new hardcopies are no longer in print.
I've attached a couple of files for you perusal. The zipped file has some photos of the enclosure I've made for the British Power Pulse modulator driver.
It can source/sink up to 340V, 9A (Freq. Range 1Hz to 1.5MHz) and has active protection. I've yet to procure the thyratron, as they are not readily available off the shelf in Australia - the most common types are Soviet made. The TGI1-50/5 thyratron according to the datasheet can handle up to a decent 50A of current more than enough to handle the remaining voltage discharge from the spark gap assembly, it also has very high di//dt characteristics [steep pulsed edges & short recovery duration] which most semiconductors struggle to handle, without the risk of blowing them up.
Some more info. about them can be found at https://hackaday.com/tag/tgi1-50-5/
Some of the Radiant Longitudinal Wave Energy is picked up by the copper cylinder around the spark plug gap(B) electrode rod after the high voltage (C) capacitor(s) have discharged . This energy is collected to mainly drive a preferred load load of your choosing and some leftover 'Cold Electricity' pulsed DC energy can also be dumped as storage into a 12V battery for charging. Label (D) is the overshoot spark mechanism designed to to protect the circuit along with the PIV shorting 'flywheel' diode arrangement connected in parallel across the high voltage (C) capacitor(s)
Anyhow that's a synopsis on how I think it  it works. It may take me another month to construct and source the remaining parts.
kolbacict
Quote from: lifeforce-energy on June 04, 2023, 01:47:41 AM
Take me to your place, and with me a ton of junk. We will make a sea container, and in addition to the instruments, I will hide in the container. ;) :)   And there I will hide in the forest with the Papuans from the migration services.  I won't be a problem for you.
I have so much trash, you don't even suspect what Ali Baba's treasures await you... 8)
