Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
0 Members and 23 Guests are viewing this topic.
gauschor
Great attention to detail. I didn't look at the amount of strings. Who would have thought that the left curved and right curved spirals are not identical in number and use Fibonacci numbers (ok ok, Bashar said it, but on the first look you'd just use same amount of strongs for each side). Why didn't we learn this in school? Nature is awesome.
WTF
I know, before I accidently came across this thread and read Bashar's description, I've never even heard of Fibonacci, when uniquorn said my wire net wasn't symmetrical I thought what is he on about, now I know. It's a good job he's here.
Hope
Cymatics shows this wire outlay to be in harmony with a pure frequency.   Building such a perfect pattern of wires could be much simpler of course later  (once a working model has been built) with a 3D printer.
Yes, Unicorq  I too believe we need to follow Bashar's work on the pattern or else what have we got.   But all through the history of mankind there is a situation that arises.   Someone says something,  someone else interprets it with a certain amount of accuracy.   I know you are being a perfect as you can,  all your heart is in this and you THINK you have been correct.   So lets take an approach that is orderly.   What can we do so we do no harm is checking different configurations?  Progressing towards more and more modification of the parts until we are at the final determined design?   All I am asking is that we check in order as non destructive as possible along a path so that there is the least waste of materials, building measuring and proving or  disproving until we arrive at the final modifications.
It is WFT's resources and time.  Let him decide what is best.  I have seen builders revise and learn through the years.  Many make discoveries and change the designs continuously until either they run out of ideas or succeed.
Even after the device works there will be revisions.  That is normal and is called progress as you know as well as I do.   My two cents on the crystals importance is that it alone is used to strip or consolidate or somehow transform flowing unknown energy through the matrix of crystal and allow it to be collected.  You decide for yourself how that can happen and checking your findings and device completely assembled.   Good luck with this!
As the energy travels through that crystal it will order itself due to magnetic's that permeate everywhere and this I believe is where the "magic" happens.  The magnetic's is like a waveband that the energy rides on.
WTF
When you look at a sunflower there's no space anywhere, so I think the wire net would have to be a similar configuration, so my 34/21 net I'm wiring up now probably won't be effective enough as there's lots of space in between the wires, if you look at this picture from you see what I mean, the only way to wire it up like that would be to use 0.1mm wire, lot smaller than specified, and the smaller the wire the less surface to pick up energy. But Bashar could of meant it to be like the picture as that would be considered very tightly interwoven.
gauschor
This last picture feels somehow wrong (on the first look), because there are much much more Sunflower kernels than could be produces by Fibonacci strings. It looks like only 8 Fibonacci strings come together in the center and all other kernels come from "sub-branches" of these 8 main strings. But if we look at this sunflower picture, we can see that this isn't the case on a real sunflower. All Sunflower kernels lay next to the main strings, which all come together in the center. Though I am not 100% sure, as the center is cluttered anyways.
It's kinda awesome looking at it and seeing that it forms a hill in the center. It emerges outward, because there is nowhere else to go for a conflux of streams but vertically upwards. Reminds me of spiral galaxies which also have a core that somehow extends the "flat disk".
