Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
Uniqorn
Quote from: WTF on December 22, 2013, 08:33:13 AM
If you can take measurements with an electromagnet that makes things a lot cheaper, as I was thinking you probably would need a laser Doppler, even then I wasn't sure if that could measure the frequency difference.
I would have thought copper plating would be too thin to work as plating is only about 0.38 microns thick, and would have thought the whole ball would need to be the same material for the experiment.
Actually,  you can copper plate a lot thicker than that, but why I suggested this idea is because he stated very thin copper was required and I thought maybe precise glass balls might be more available than thin copper balls, which would be quite fragile. As to wether a mix of glass and copper would work, I cant be sure.
WTF
Well I made it and its not working, the wire net is a proper Fibonacci spiral, and the quartz looks real to me and is colder than glass. So I conclude Bashar is fake.
I tried to upload the pictures but this site won't seem to take them.
hartiberlin
@WTF
please only post small sized pictures with not more than about 800x600 pixels
please !
Uniqorn
Wow WTF, I'm officially impressed with your efforts. You don't just talk about, you Get It Done!
However, you haven't finished yet - you've got to check, double check, mess about and experiment before you pack it in an consider it done.
Have you checked the circuit for continuity where it should be and shorts where they shouldn't? Are the wires in the spiral mesh dense enough, and truly Fibonacci? Can you post more pictures showing more detail, and give a report on any tweeking you may have tried?
Once you have done all of the above, then you will have made a more valuable contribution by giving a more definitive answer.
Quote from: WTF on January 07, 2014, 09:53:36 AM
d3x0r
if they are more than a couple hundred K you can usually edit your message and attach them one at a time... but it doesn't always reload to the message... if it times out, go back and reload and the image will be attached...
