How to make multiple Kicks
Started by Neo-X, November 23, 2013, 10:31:20 PM
forest
Like Tito said, TPU works the same way like others.... frankly I don't see another source.... you must read Tesla related patents 20 times or more and then ask : what should I do to make it working with very low input power, what is missing (removed?) from the patent ? For that you must follow what is going on in patent very very closely and find the weak point...
forest
and by the "weak point" I mean something which forbid actual ou. The very problem is like Tesla stated - it is not single invention , it's art of wireless power
Dave45
Quote from: Neo-X on November 25, 2013, 03:21:20 AM
I copy some of steven mark posting that related to the perpendicularity of the coil. The clear only in what he said is the control coil must be perpendicular to the collector coil.
OK let us compare this story of the common radio.
Think of the power unit as a device similar to a radio receiver.
No I do not want to hear feed back informing me that I am trying to convince the world my unit works on radio waves!!!.
But it behaves very much like a simple radio receiver except for the fact that radio waves need to be amplified before they can be of any use to us.
My units behave as though they are variable tuning devices, and we are tuning them to a frequency just like a radio.
The closer you get to the center frequency the more power you permit the collector to dissipate into a load.
the important difference here is that in the case of the radio, you tune into the frequency and amplify it for use.
In the case of my power unit, you create several frequencies within a space of the collector coil's circumference.
The frequencies are directly related to the circumference of the collector coil.
You can begin to collect the current and dissipate it with no need for amplification because the signal source also becomes the feed for the power source and has the natural tendency to run with gain.
It is important that you note that you can never tune too closely to the exact frequencies of power conversion because the power received by the collector will instantly destroy it.
We instead must deliberately tune off the frequencies of conversion in order to make the thing properly work.
Remember that it is like a furnace which feeds itself.
The hotter it gets the more fuel it gives itself to burn.
That is why the control units are so very important.
Without the control unit constantly monitoring the frequencies of operation and making the necessary changes to keep the whole thing off exact conversion frequency, then the unit would very quickly destroy it's self.
Listen, you need to make three coils or so one on topof the other.
But the important thing is to wrap the control coils perpendicularly around the collector coils.
There need to be three of them all the wayaround.
Start them up one at a time each.
Firstfrequency then second harmonic component into thesecond, then the third.
When you eventually strike thecord look out.
you will know what has happened at thatpoint.
In the mean time you can measure a slightoutput even if you do not strike the exact cord.
Larger collectors have a much greater ability tocollect and dissipate more energy then the smallerones. However, if they turn into a bomb it will notmake much difference...
There is no such thing as asmall lightning strike.
Perhaps a smaller one is saferbecause the only thing that will stop a red collectoris the disintegration of the matter acting as areceiver. IE. the wires all burn up.
Sounds great, got a schematic  :)
Bruce_TPU
@TK
YOU are the fake and fraud, not SM.  Just because you don't have the aptitude to figure it out.   :P
@ALL
To make a single kick you only need a switch,  even a manual one, a voltage source, no current,  a resistor and scope.  Simplest thing on the planet.   ::)
Cheers,
Bruce
YouTube: Moved on to a relay from a manual switch in this video. I also built a magnetic sensor and that is what you see on my scope.  It does NOT pick up voltage, only current and then changes it to voltage to be picked up by the scope.  Later I moved on a 10 ohm resistor and learned to make many more and MUCH larger kicks.
http://www.youtube.com/watch?v=UoVgSGbE2Vk&feature=youtu.be
AND
https://www.youtube.com/watch?v=-wnEr0O75Sc
rensseak
Don't forget that there is still a fourth frequency and that is the Schumann-Resonaz in which to tune but not to close.
