Super simple way to see proof Pseudo Solid principle works using ring magnets
Started by gammarayburst, December 03, 2013, 04:51:41 PM
profitis
@gammarayburst out of curiosity did you ever manage to witness a self-sustaining magnetic device giving repeated full cycles at a gain?
dieter
Hope you don't mind if I answer.
The fact that something doesn't exist doesn't mean it is impossible.
For instance mankind had fire, metal etc. for thousands of years, and the following things have always been possible: Vacoom cleaners, Cars, Airplanes, TV, Cellphones, Spaceflight.
These things, among others, have always been possible. But it took some genious minds to actually invent them. They didn't drop from the sky into the hands of the scepticals.
What is really interesting here is the quint essence of pseudosolid ferromagnetics. We wouldn't research in this field if it wasn't promising, after doing all kinds of experiments with magnets for like 30 years.
So if you have doubts, specific arguments are certainly welcome.
BR
profitis
No I just want to know if he's seen anything as he works with magnets all the time.maybe a penulum or motor,smot or something etc..btw @dieter what did you do with your gold leafs?
dieter
I still got most of the goldleafs, tho I was using a bit for electrodes.
@all: I've made some tests with a very crude setup. All I can say at this moment is, keeping a magnet between two pieces of iron, maintaining an airgap on both sides, is extremly difficult, esp. with a magnet that sits at the perimeter of a rotor. Even in a rather rigid construction, the slightest freedom of the bearings will cause the magnet to stick to one side. Which results in extreme friction. Therefor it is essential to prevent that, eg. by a wheels system such as in Floor's PDF, or with a high efficiency lubrication.
Furthermore, the attraction and repulsion of the rotor results in horizontal changes of pressure between the synchronizsation gears, causing further friction. Tho, a rigid construction (my wooden base was slightly flexible) may prevent that, but still, the gears are not a perfect solution.
I can however confirm that the rotor is repelled, once the magnet has passed over to it. But that was to be expected. I can not say which force was stronger and if there was any net gain, simply because the friction was too high, due to the magnet sticking to one metal sheet, on both, the rotor as well as the horseshoe...
I have to think about how to implement this in a better way, to prevent the mentioned complications.
BR
BTW. A guy named Nick Moore has an interesting tube vid about using ferrofluid for lubrication of permanent magnets. Although, it's a bit of a mess, it get's extremly slippry.
gammarayburst
Quote from: profitis on February 11, 2015, 02:01:31 AM
Profitis, No I never in my life have seen a true self sustaining magnet motor. I do feel that if I had the funding I would have one based on the Pseudo Solid Effect. The power in to the power out is so positive it would for sure work. Building a machine that can maintain .005" air gaps will cost a lot of money.
