Forward EMF Collection
Started by d3x0r, December 20, 2013, 01:57:07 AM
Dave45
Quote from: totoalas on February 09, 2014, 03:20:48 AM
try to connect the earth to the core :)
That should charge the core with a neg charge and attract even more pos ions.
Its about charge attraction folks a neg charged coil will attract pos ions from the atmosphere, collect the pos and pulse another winding to attract neg ions, we need both.
Dave45
Some authors hedge by making the following statement. In general, the atmospheric medium, by which the near Earth is surrounded, contains not only electric charges bound in atoms or molecules, or any form of matter, but it also contains a quantity of charge in an unbound state. Sometimes the unbound charges are positive, sometimes negative, but as a general rule most are of an opposite polarity to that of the Earth. Different layers, or strata, of the atmosphere, located at only small distances from each other, are frequently found to be in different electric states.[5]
http://en.wikipedia.org/wiki/Atmospheric_electricity
We have pos and neg charges all around us but claim only neg charge flows in our circuits.
http://www.trifield.com/content/about-air-ions/
Dave45
I should have studied this along time ago
http://www.electrostatics.com/page2.html
A magnetic field attracts charges from the atmosphere, if that field is collapsed those charges will collapse as well.
http://chemtrailsplanet.net/2013/07/25/how-solar-flares-directly-affect-human-consciousness/
Our planet has a neg charge the upper atmosphere has a pos charge, if our coil has a neg charge then the air around that coil has a pos charge and when the magnetic field of the coil collapses it will bring in a pos charge.
Its about charge separation, to collect before they cancel each other out.
Dave45
Dave45
Making a plan  :)
QuoteIn order to gain the most benefit from your static neutralizing or static control equipment, it is important that you understand how they operate and how they provide the means of neutralization. Most electronic static neutralizers are constructed by placing a high voltage on a sharp point in close proximity to a grounded shield or casing. There are two basic types static control ionizers- AC & DC
With Alternating Current ionizers the high voltage alternates current pulses through the 60 cycle operation, the air between the sharp points and the grounded casing is actually broken down by ionization and therefore both positive and negative ions are being generated. Half of the cycle is utilized to generate negative ions and the other half is utilized to generate positive ions. On 50 or 60 cycles per second power grid polarity is changing ionization every 1/100 or 1/120 of a second.
If the coils are in close proximity to each other they cancel each other, by running each leg of ac to a transformer we are generating both pos and neg ions in close proximity to each other and cancelling any ambient return, we must separate the coils on each leg by enough distance that they dont cancel each others field.
