Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
MenofFather
JohnnBlade, maybe you need use more lower frenquency of space if you not using any back pach? Or ajust R11 if you using back pachs.Can you make photo of your divice and show that going from Tl494 in oscilioscope photo?
NickZ
  Although finding the coil or ferrite core resonant frequency may be a simple matter, this does not guarantee a self running device.  Each coi/core combination will have it's own set of normal running frequencies, but they may not really do anything unusual, as most ave found.
  Dr. Stiffler has mentioned something about a resonant "Spacial Coherence", as being different from the circuits normal running resonant frequency. This may be what we should be aiming for. And not just whatever frequencies are emitted by the coils or cores themselves, as those will be different with each circuit. So, there may be no point tuning to a certain fixed frequency, as that may not be where the extra energy is found, but looking for this spacial coherence factor, instead.
  Check into this Spacial Coherence,  as the Doc was able to light several leds, without  any external input, at all. Possibly this is what may also going on in the low output devices as well as the higher output ones, that people like Akula is showing.
  The Docs findings are not BS, faked, or misleading, and have been replicated to some degree.
verpies
Quote from: tysb3 on May 01, 2014, 06:43:19 PM
yes, I'm staying, I'm  repeating what was told  in conference with Akula:
1) find your transformers core resonance.
...and right off the bat you are very ambiguous.
Namely, what resonance frequency are you writing about?:
1) LCR resonance (what C ?)
2) Standing EM wave resonance inside the core (related to its permeability and permittivity)
3) Nuclear Magnetic or Nuclear Acoustic Resonance
4) Electron Spin Resonance
5) Resonance of acoustic standing waves (a.k.a. "dimensional resonance")
    a) transverse
    b) longitudinal
    c) torsional
MenofFather
Quote from: verpies on May 02, 2014, 11:26:52 AM
    a) transverse
    b) longitudinal
2) tune HF generators coil in resonance on 1/2 or 1/4 or 1/8 frequency  transformers core resonance. you need to have 2 resonances at one time. ignorant people don't listen that.
Need found feroresonance. Then ask Akula or it is mechanic vibrations or that, somthing like this, he say, that maybe be and that and that, somthing like this he say, he himself wery good not know that it is resonance. But only here not LC resonance. And core resonance ferite not strongly depeends how much you wound turns, if you 100 meters wound, then sine be рваное, how he say.  :)
I try decode...
Григорий: А у кого-то есть вот дома генератор и осцилиограф на несколько мегагерц?
Акула: Ну, у меня есть. Привет, кстати всем!
Григорий: Да, привет! У тебя понятно, ты ж какбы не хочешь это... раскрывать секрет.
Акула: Нет, ты вообще не прав. Я абсолютно расказал своё видение работы, показал осцилиограммы, дал схемное объяснение. То есть, ребята... а то что я не оспариваю чьи-то мнения, ну это же совершенно другой факт. Почему вы так заявляете, что я не хочу? Я абсолютно всё показал, причём не на одном схематическом решении.
Неизвестный: Ром, (Акула) слушай, раз уж такое дело: как так получаеться, что при ферорезонансе там всплески появляються, когда видео, где частота генерации в районе 20 герц, а частота на ферите около 250 герц и там не синус а именно всплески, от куда там всплески беруться, вот это хотел спросить.
Акула (Рома, Роман): Ну смотрите: у меня ВЧ (высокой частоты) генератор работает именно на частоте ферита. То есть сигналы идут... вот эта микросхемка 34063, она как раз создаёт сигналы, скважность которых не превышает частоту ферита, а равное ему. И вот уже работая на частоте ферита, она формирует низкочастотные колебания общего ЛЦ контура получившегося.
Неизвестный: Счас попробую осмыслить.
Акула: Объясняю: То есть первоначальный генератор ВЧ, он открываеться, допустим, представим, у него же там внутри транзистор есть, так вот у него транзистор открываеться и закрываеться с таким же временем работы ферорезонанса. То есть, когда у нас транзистор на ВЧ генераторе открылся, он не пересекает время работы феромагнита. Поэтому он не жрёт практически ничего, то есть схемы потребление идёт нулевое. Ей лишь только необходимо дополнять электроны, потому что она всё равно их тратит на эти моменты открытия и закрытия транзистора. Проще говоря: вы нашли ферит, допустим частоту, она, допустим равняеться два с половиной (2,5) мегагерца, вот, засекаете время амплитуды пол волны, так вот ваш ВЧ генератор не должен открываться и закрываться дольше, а должен открываться и закрываться согласно этому времени. И уже пачками импульсов, согласно ферорезонансу, мы формируем уже низкочастотные колебания.
Григорий: Будет ли опубликованна схема фонарика номер 3? Такой первый вопрос.
Акула: Будет опубликованна, только когда - не знаю.
Неизвестный: А где посмотреть первый, второй, третий?
Акула: Только у тех ребят, здесь и сейчас есть наличие видео, могут перекинуть. У меня, но в принципе... я ссылки давал, они сейчас имеються. Видео находиться в закрытом досткупе, но ссылки имеються. Могу сейчас эти ссылки поместить, этих видео.
Неизвестный: Если можно пожалуйста.
Акула: Да и ещё... а в принципе там по поводу опубликации схемы, ну а что там опубликовывать? Два генератора. Там нечего то и опубликовывать в основном.
Вопрос: Какие частоты идут с каждой ТЛ494 и какая скважность в процентах приблизительно?
Акула: Низкочастотный 50 процентная. ВЧ генератор работает на времени ферорезонанса.
Григорий: ВЧ - это ферорезонанс? Да? То есть пару мегагерц, взависимости от ферита? А низкая частота какая?
Акула: Нет! Там частота может быть и 200 килогерц и 300 килогерц, а скважность этой частоты как раз и равняеться времени ферорезонанса.
Неизвестный: А во, Роман, как объективно увидеть, что ферит вошёл в резонансную свою частоту?
Акула: Ферит не должен входить в резонанс на свою частоту, ребята, вы не увидете там на осцилиограмах нигде амплитуду ферорезонанса. Вы лишь изначально её проверяете для определения времени скважности работы ВЧ генератора.
Неизвестный: То есть получаеться генератор генерирует эти, не помню, 13, ну вобщем, в районе двадцати герц, но со скважностью отностительно ферорезонанса, так получаеться?
Акула: Да, вот этот ВЧ генератор, который у меня на осцилиограммах же был жёлтый, на самом деле он там... частота импульсов следоваиния почти 1 мегагерц, но скважность их ровняеться 3,5 мегагерца, потому что ферит, чашка звенит на 3,5 мегагерца, в районе, в районе этого.
Григорй, следующий вопрос, такая фраза, что значит пришлось подстраивать фронты, выходной транзистор ТЛ генератора трансформации?
Акула: Если низкочастотный генератор, который работет на 50 процентной скважности и формирует низкочастотные колебания, если время открытия транзистора и время закрытия транзистора превысит время ферорезонанса, то вы нарушите работу, основную, ВЧ генератора. Ну это ж логично.
Here decode some part, you can now try translate ewery word and know that exatly saying Roman (Akula).
lost_bro
Quote from: MenofFather on May 02, 2014, 11:42:05 AM
Quote from: lost_bro on May 01, 2014, 09:22:36 PM
........I do *not* understand that the XL, XC resonance spoken of above to be the *type* of resonance that Akula talks of in the tape transcripts.....
Apparently he states many times the word *ferro resonance* and relates it to the type of resonance he *believes* his circuit is experiencing.
I would assume that someone who can design a SMPS type (O.U.????) circuit understands the difference between Ferro resonance and Common XL,XC resonance.
Just more food for thought as I play the devil's advocate ;)
take care, peace
lost_bro
So again, it is re-iterated that is is *NOT* only the LC inductance of a coil set that is at play here.......
: Well, look : I HF ( high frequency) generator is running at a frequency of Ferit . That is, the signals go ... here this mikroshemka 34063 , it just creates signals duty cycle does not exceed Ferit frequency and is equal to it . And now, working at a frequency of Ferit , it forms a low-frequency oscillation of the LC circuit resulting total .
Unfortunately, its seems Akula does *not* understand exactly which *other* species of resonance is effecting said reaction.
take care, peace
lost_bro
