Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
Thestone
Quote from: EMJunkie on April 27, 2014, 06:44:36 PM
Hi Thestone,
I have not spent huge amounts of time studying this particular schematic! I would not like to explain this circuit because some of it does not make sense to me either! ...
All the Best
  Chris
Hi Chris,
Yes it does not makes sense... then how we are going to replicate this, if we don't understand it... I think that there are several things in common in most of his schematics... the PLL, inverter, IR211, etc, but we need to be able to understand the circuit well in order to duplicate it, and I agree with you, there got to be some missing things on the schematics.... as I don't see either a close loop here...
But I think that the "Signal advance/Actual/delay" has to do with the phase shift you are talking about. but there is a fourth signal too, I believe.
let's see if someone else wants to take a shot... hehe  ::)
EMJunkie
Quote from: Thestone on April 27, 2014, 07:53:44 PM
Hi Chris,
Hey Thestone,
First of all, I must apologise! I have inadvertently confused the situation. I should hot have posted this schematic! I only posted to show the concepts of Phase Shifting that is apparent in many of Akula's Schematics and not only that one.
We need to start at the start! Start with something small, the least confusing, and something we have the most information on. "Little Steps for Little Feet" is what I value the most from Richard Feynman!
I think to date, the best place to start is Akula's Lantern No 3 which -->havuhung - Akula's Lantern No 3 - Circuit<-- very kindly reverse engineered and has shared the schematic for!
We know a lot of information on this device! TV Flyback Ferrite cores are readily available either if one can salvage from an old CRT TV or source on E-Bay -->FERRITE CORE<--
We know the Turns and direction of the turns!
We also know the approximate frequency of: 6.910KHz Approx.
We now also know the Circuit thanks to -->havuhung - Akula's Lantern No 3 - Circuit<--
So regarding the other, complicated, incomplete circuit I posted, please Ignore it and lets concentrate on what we do have.
All the Best
  Chris
P.S: Thestone, are you able to explain the PLL (Phase Locked Loop) you can see? I don't have a lot of experience with PLL, know of it and know a little about it but not by any means experienced with it!
Thestone
havuhung
Quote from: EMJunkie on April 27, 2014, 06:51:59 PM
havuhung! Excellent work!
This also shows what I have been trying to explain, 'Phase Shifting' on the input signals to achieve something we may not be fully aware of yet! See: -->www.hyiq.org/Downloads/AetherControl.wmv<--
Thanks for sharing!
All the Best
  Chris
P.S: Remember what Tom Bearden said about interfering two waves at a distance?
Hi EMJunkie,
Thank you.
havuhung
Hi All,
Add a hand-drawn schematic diagram. . .         (Realstrannik.ru)
