Gravity wheel of Krstan Pejic. This device works
Started by Shokac, March 26, 2014, 04:09:05 AM
memoryman
The likelyhood of this contraption delivering OU is best expressed in scientific notation:1/10^googleplex. But then, I AM an optimist.
Quote from: madddann on March 26, 2014, 09:12:47 AM
That's not even too expensive... 587 USD maybe Sterling Allan would buy it  :) .
                                     ;D Yes,absolutely,clearly ! ;D
But:                    1.000 Russian Rubles ~ 28 US$
                           2.000                              ?
                         20.000                              ?
                       200.000                              ?
                                             :-X :-\ :'(
Adeus
          OCWL
p.s.: thread object http://www.patentauction.com/patent.php?nb=8747
gyulasun
Quote from: lancaIV on April 22, 2014, 04:54:53 AM
                           2.000                              ?
                         20.000                              ?
                       200.000                              ?
Olá Lanca,
1.000 Russian Rubel is 0.028 USD  and not 28 USD if you meant that (any source: http://themoneyconverter.com/RUB/USD.aspx )
So 200,000 RUB is 5,600 USD (5 thousand and 6 hundred) and not 587 USD as member madddann wrote.
Greetings, Gyula
EDIT  I just realized that you use dot where the English use comma (virgula) to cut up the thousand values. So one thousand Ruble is indeed 28 USD nowadays but it is written as 1,000 RUB and not as 1.000 RUB, this is why I speak up...  8)
Mind91
Hello
First, this is new video from Krstan Pejic. He is saying that every few seconds he is using electricity from battery, and electricity used is lower than gained because of flywheel. Don't know does this video has something to do with old one, just posting if someone wants to comment.
https://www.youtube.com/watch?v=hy-XAI-9yaA
Now, this is what happened with this project. Atm, he made this generator to work on home electricity, spending about 1kw and producing 7kw. He already selling them.
Interesting thing that he says in video (not this that i posted but original) is that at that time when video was recording he was already on project for 1 hotel where he is making generator of 40kw. This means that going from generator that is in video which is using about 100w per hour while producing 1.5kw to generator that he is now selling (1kw to 7kw) is not problem, pattern is same.
As he himself sad to 1 visitor, we all can see from video what he was using and to make same "hardware", but real deal is in that alternator. That is not just random car alternator hooked up and lets go. Something was changed in it. Only thing i can think of is that he made it to be permanent alternator by adding magnets.
Alternator, inverter and how are wires hooked up, are so far mystery.
Since last post was about 1.5 years ago, i would like to use this opportunity to ask didi someone found out something new, maybe tested generator? I personally tried to make it, but it did not worked with just random alternator hooked up.
Thaelin
   You can seriously do better than a car alternator as per a repair shop they are a very bad and lossy generator. Consider the design for a wind generator instead.  You could still use a coil to make the magnetic field for it and by that control the amount of output as you would in a car unit.
