COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
ARMCORTEX
But you've never heard... It dont matter what you heard, this is groundbreaking tech of course you would of never heard of this.
They provide power readings, surrounded by big shot engineer millionaires.
This is not to be taken lightly, obviously they have something.
If Stephan, with his ''conventionnal understanding'' can see clearly the process, then It surely must be ''comprehensible concept''.
It shouldnt take long for someone to make a condensed informative prezi.
Stephan, state clearly what should be done plz.
hartiberlin
Here is a quick basic circuit diagramm.
The switches must be replaced by MOSFET switches with the right timing and
control circuits.
But this shows how 2 caps can be put in series or in parallel.
I still pondering, why they did use 2 lamps as the load.
Maybe they are also switching the 2 lamps once in series and
then in parallel to have a different load resistor and thus control the charge
and discharge current better to get about equal areas in the input power
MATH trace, so the Real Active input power is minimized and only reactive power
is drawn ( just oscillating power).
Regards, Stefan.
hartiberlin
Here is the circuit with timing diagram.
Shown under the i(t) current waveform are the switched that are closed
in this timeframe.
so S1 S2 S4 means switch S1, S2 and S4 are closed.
Regards, Stefan.
MarkE
Stefan what do you mean by the circle with the X in it?  That normally symbolizes a multiplier.  Do you mean that to be an AC voltage source?
Anyway, charge shuttling / balancing circuits have been around for a long time for use in DC systems.  For AC the switches and drivers get more complicated.
e2matrix
I already knew the answer MarkE but just so there wouldn't be any argument about it here's top of the Google
