Akula0083 Light No3 - Dual TL494
Started by JohnnBlade, May 08, 2014, 11:34:00 AM
JohnnBlade
I forgot to mention that the ringing pattern only happens when the input is at 4.91v @ 40mA, when i turn the input up to 5.41v @ 140mA the whole ringing goes away and turns into the second picture.
Greets JB
JohnnBlade
Here a shot of both signal gens together, its the same ringing but then the other way arround
1e frequency is 538.85kHz
2e frequency is 30.33kHz
Input is 4.34v @ 30mA
2e pic looks like a bo tie :) just showing probaly not relevant
Greets JB
d3x0r
Quote from: JohnnBlade on May 10, 2014, 02:15:14 PM
Greets JB
Haha ; nice shot of 'negative resistance'!   beware.
It's actually 'resonant rise'...
the low frequency is squelching the buildup from the higher frequency... so you get to watch the beginning of resonance.... usually we only get to see the highest state ... when it gets to 'cruise altitude' sorta
but ... what are both frequencies?  I kinda misread 1e and 2e to mean something about clock1 and clock2....
JohnnBlade
Quote from: d3x0r on May 10, 2014, 02:30:36 PM
IC1 on the circuit is set at 538.85kHz
the 2e IC2 is set at 30.33kHz
if that is what you mean ?
Greets JB
JohnnBlade
@ D3x0r
i just did a quick google search on this "negative resistance"
In most situations the circuit resistance will have a positive value. This means that  is negative and the oscillation's amplitude declines exponentially as time passes. In effect, the circuit starts with an amount of energy stored in the inductance by the starting current, . As time passes this energy is dissipated by the resistor. The oscillation energy fades away and the resistor warms up. However, if we can arrange for the resistance to be zero, the initial current starts an oscillation whose amplitude remains unchanged as time passes. None of the oscillation energy is ever dissipated.
A negative resistance value means that  is positive. This means the oscillation amplitude and energy grow exponentially with time. In practice, we can't ever obtain an oscillation whose energy grows larger without limit. Infinite powers and energies aren't accessible in the real world! Something always restricts the rate at which the system can 'create' oscillation power. Fairly obviously, this power must also come from somewhere!
http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/RadCom/part5/page1.html
http://en.wikipedia.org/wiki/Negative_resistance
so is this negative resistance any good for this Akula circuit?
greets JB
