Russian Overunity Resonance Transformer
Started by synchro1, May 09, 2014, 03:46:33 PM
Dave45
Ya know the grid cycles at 120 hz but we get only 60 hz in our homes....................why
Dave45
Quote from: Dave45 on May 13, 2014, 10:11:04 AM
If current cycles at 60hz and the voltage cycled at 60hz=========120hz
Wrong terminology
If neg cycles at 60hz and pos cycled at 60hz==========120hz
Dave45
Why is the current and voltage 90 degrees out of phase
We are hitting the primary at 180 degrees, one side then the other.
Four pulses two pos and two neg alternately broken down - 1/4 phase - 90 degrees
MarkE
Quote from: Dave45 on May 13, 2014, 10:42:33 AM
Wrong terminology
I think you are confusing voltage and current cycles with the power half cycles.  The mains voltage is a sine wave at 60Hz.  Each half of that cycle the magnitude of the voltage and the magnitude of the current and the magnitude of the power all go from zero to maximum and back to zero.  If the load is purely resistive they all do that in unison.
Dave45
Quote from: MarkE on May 13, 2014, 11:25:28 AM
Easily said but put it into a descriptive drawing, I could talk about it all day but to put it into a mechanical format is a little harder.
That being said I do appreciate the feedback.
dave
