1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
alfilmx
Artoj
Hi Luc
I posted the incorrect picture, so I deleted the post , here is the corrected version and another type that maybe even easier to build. The first picture still requires the stationary center shaft, but the second picture shows that the centrifugal action will throw the smaller wheel(pulley/gear/sprocket) around, to ensure that it does, load up some weights on it. Also to stop the vibration you could add a secound wheel on the other side just to balance it. The important ratio is 2:1 of the wheels and 2.666:1 of the pitch center on the smaller wheel to the lower shaft center attachment, I have a few more versions, but I think these should be simple to implement. My Hyperbolic Drive design maybe a little too complex for the type of build you are doing at present, it would be very close to Skinners design, as this has taken me years of work to simplify to this basic outline, which can be used for all sorts of non-linear rotary actions, never underestimate the complexity hidden is some simple arrangements. I hope this helps, regards Arto.
Artoj
In the pictures it does look like the a belt is around both wheels, this is not a belt, just a doodle showing my ideas and that they are connected , if you did use a belt or chain you would have clearance and use the arm that is above to guide the smaller wheel, or if it was a chain this would be ok as long as there is clearance and maybe wouldn't even need the arm guide, as it is being thrown out clearing the other sprocket. If they were gears then this would be perfect to connect together, as the ratios and smoothness would be superior. Anyway I did this to help out, It isn't the best way to implement the types of gentle actions required to move a rotating lever arm. But as they say let the FORCE be with you, as for me force is not required.  Regards Arto.
noonespecial
Actually if you want a 2:1 ratio, the two gears C1 and C2 will need to be the same size.
