KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
profitis
Nor is there any internet info that can show that such spillover is irreversable @sarkeizen.I find that intensely suspicious.you must remember..karpen was also playing with hydrogen cells..open up dogaru and cazacu's referance at the bottom of the wikipedia article on karpen.
pomodoro
Don't know about the chloride I have to ask around, but I have 10%Pd on activated carbon.  This stuff is expensive so I don't want to waste it.
Regarding your suggestion of Karpens #2 picture, you propose the upper electrode be half exposed to oxygen , the other submerged in the acid solution or alkali?  Any use of any other chemical such as benzene?  What about stirring?
profitis
Platinized platinum will have to do for our future hydrogen experiment then @pomodoro.if it was platinized by the manufacturer company then it will do fine.if it was platinized by you then alot will depend on your platinizing skills because the platinum black must be totaly adherent and conducting straight onto the underlying foil. Karpen did not use benzene in figure 2. He used one single electrolyte and so did I in my series of tests a few years back.take a solution of sodium hydroxide under air and touch the surface with the bottom end of a PLATINIZED(black) platinum foil.take a aqua regia etched smoothish platinum foil and immerse it totaly under the electrolyte next to your platinized cathode.you will now get perpetual current bursts in the region of 50-100 micro-amps/cm2 if you do this properly. The surface platinized electrode is your cathode(+).the submerged non-platinized foil is your anode(-). this is an oxygen gas concentration cell.the nernst equasion applies.the larger you make your anode and cathode the larger your current.voltage is about 0.1-0.2v
profitis
Do not stir the above @pomodoro.we don't want people to say stirring powers the cell.leave the cell dead still once sealed.use platinum wire as your leads out the cell.
pomodoro
Ah OK now I understand. You believe karpen's cell woks because the pt concentrates oxygen from air, due to its nature, and the gold does not, thus a concentration cell is formed.  So, if I have a working model in air and put it under vacuum absolutely no current would flow, correct?
