Akula eternal lantern 4
Started by MenofFather, June 01, 2014, 01:15:57 PM
hartiberlin
Quote from: avalon on June 02, 2014, 01:38:19 PM
I cannot tell for how long Akula's devices managed to run. However, I ran my circuit for a week before manually switching it off.
I have not, however, tried it with a few LEDs attached which may result in a short run time, primarily because I am not interested in creating yet another lantern. I will show a high output device when it is ready.
Anyway, the effect is real and can be harnessed. Akula is not entirely correct in his explanations regarding the nature of the phenomenon, but it exists and can be applied easily.
Have a look:
http://youtu.be/vgYLVyswgeQ
~A
Well done ! How did it oscillate on, when you removed the gate driver pulses from your function generator and also removed the power supply ? Or did you feed it still
with the drive pulses from the function generator at the end and only removed the power supply ? How big is your electrolytic cap ?
Regards, Stefan.
hartiberlin
I attached the circuit diagrams and the link to the HD youtube video now to the
first posting of this thread , so it is easier to find it all..
Regards, Stefan.
avalon
Quote from: hartiberlin on June 03, 2014, 03:29:45 PM
Regards, Stefan.
Once I tuned and knew the frequencies I made a MAX931-based gen to drive the circuit. The cap is 2200uF/63V.
~A
corry
... I ran my circuit for a week before manually switching it off...
Hi Avalon,
diagram of your setup ?
Thanks
d3x0r
Quote from: MenofFather on June 01, 2014, 01:15:57 PM
https://archive.org/details/fonar4 this seems not play
https://archive.org/download/fonar4/fonar4.mp4 open with VLC player.
That can I write about this lantern? Here is one frenquency. Frenquency is about 250 herc of wery short pulses. One pulse duration about 10-20 microseconds. Here is two coils one primary, other secondary (turns how much each coil I don't know), from secondary going througt one diode seems to capasitor (capasitor is not less than 50 volts) from that working this divice. Is also and 3 coil who in now in this video not used (in future Akula plan use it to stabilise this lantern and it better work, but NOW here is fixed frenquency and sometimes it can stop working, why? Akula exatly don't know).
And first he start from 9 V battery from lower frenquency, because with higher frenquency lantern not start and after start he can make higher frenquency to get more power from lantern (LED's brighter shine).
:D
Admin added:
Here is the new Lantern circuit number 4 in HD rendering I just made.
http://youtu.be/DnuXqnTlJNM
Here are the 2 different circuit diagrams attached.
I saw your schematic with extra stuff removed. ... L2 is connected backwards (38 winding) and the LEDs are backwards, they are driven from negative potential to ground
