Longitudinal Wave Experiment to demonstrate Overunity
Started by magpwr, August 16, 2014, 01:12:29 AM
poynt99
Quote from: magpwr on August 20, 2014, 07:14:48 AM
hi MarkE,
I have done that already for someone whom requested it earlier in this topic.
I have previously attached the image of watt meter with circuit.
The watt meter showed zero watt which i was not surprise due to it's limitation in handling very narrow spikes.
Latest update -I have added 10000uf capacitor before fuse to remove spike so that we can see clearly how much current the circuit is really consuming.
Using 0.1 ohms resistor after inserting 10000uf capacitor i am finally able to see the current draw for this circuit.
85mV/0.1ohm =850mA (DC after circuit stabilized) at 6.6v input.
By adding even higher value capacitor i am still unable to get the watt meter to function.
This is it guys.This is the most accurate presentation of input current in dc i can produce
For this experiment i have attached the most important video which everyone was looking out for.
Estimate power in watt ignoring the really really tiny ripples=0.85Ax6.6volt=5.61watts.
5.6W input? I could buy that. Now an output power measurement is the next logical step. I estimate it is around 4W as per my last post.
Can you post the circuit files of this latest circuit? I have MS v11 and may try to run this sim myself. Thanks.
PS. may as well get rid of that frequency counter...it doesn't provide the correct frequency anyway.
MarkE
hi MarkE,
The arrangement hat you have with the big ideal capacitor and resistor has a time constant of 1ms which is nicely much longer than your pulses and will give you an accurate input power reading after 5ms or so of run time.  You can build a similar power measuring set-up for the output by placing a 0V voltage source in series with the low side of the bulbs and inserting an E element AKA VCVS into the design  that measures the voltage across the bulbs.  You can then either use a second E element with an equation referencing the current of the 0V source multiplied by the first E element output voltage (put a 1 G Ohm resistor to ground from its output to keep Multisim happy) or add an H element:  CCVS and use a multiplier.  Take the resulting output and put it through a 1ms (160Hz) low pass filter and you will have your average power after a run that is at least 5ms.
magpwr
Quote from: poynt99 on August 20, 2014, 08:34:35 AM
hi poynt99,
FILE UPLOADED-
http://www.filedropper.com/longitudinal
I hope you can present better to MarkE and us.Thanks.
I have previously tried all the imaginable approach and failed to extract dc power in multisim.
My future plans in actual project would be replacing the 1mH at the output to few turns of a transformer which via L/C meter to get 1mH.Untested and verified. Too bad there isn't suitable transformer for this job in multisim.The secondary output of that transformer would then be transformed to dc eventually.If anyone understand what i'm talking about. ;)
The only best way i know of.
Another long shot approach is to tweak capacitor to lower value to run at high frequency to power Telsa transmitter at it's resonant frequency and grounded of course.
The  receiver telsa coil will be tuned to received this power wireless and grounded.I hope someone understand what i'm talking about. ;)
poynt99
Can you try the upload again please. I get an error when trying to extract the file.
MarkE
Quote from: magpwr on August 20, 2014, 09:03:50 AM
hi poynt99,
Please extract pdf from zip to a directory.
Then open windows cmd dos box.Then navigate to the directory where file is saved.
Then copy and paste this-   ren *.pdf  *.ms11   (This is to rename the file extension to .ms11 from .pdf)
You can build any transformer you want in SPICE.  The most basic nearly ideal transformer is just two inductors coupled with a K element.  The inductance of the primary inductor of an N:1 transformer is N2 times the value of the secondary inductor.  You can of course add the winding resistances to and set the coupling factor, and add other parasitics to refine your model.
The zip file doesn't work for me either.
