Oscillating sine wave LC tank magnet motor.
Started by synchro1, August 31, 2014, 09:26:50 AM
synchro1
Both George's hoax videos rival "Verproject" for their cleverness. R.P.M. is no measure of torque. Rotor pressured slip is. Rotor speed and voltage are fixed, only current can vary. Pumping water with the wash tub synchronous motor requires much more amperage then merely moving an unloaded rotor. How much pressure does it take to slow the rotor down? The pressure required to stop the rotor is directly proportional to it's amperage. This is a measure of torque. The rotor's turning at a constant 60 hertz regardless of the amount of amperage it's using. The lower the amp draw the easier the rotor slips.
These finding's don't mean the sine wave motor is unreasonable.
synchro1
Look how these two drain motor coil cores power a hard drive with 60 hertz A.C.:
https://www.youtube.com/watch?v=FHgw_l-Z_s0
Multiple rotor magnets may multiply frequency this way to exceed the CMF threshold with identical twin output coils, and eight rotor magnets. Enough N.S. rotor magnets on the disk would cause a propulsion force from the pickup coil cores.
It would take two rotors one over the other, with two magnets on the lower power rotor and six on the upper output. The output coils would need to be on the upper level with the 6 N.S. magnets. This would multiply the CMF by 3.
synchro1
Simply mounting a rotor wheel with N.S. magnets on the drain motor impellor and tapping the output from the side with another core coil would multiply the frequency over CMF for the propulsion effect.
The drain motor core coils can be used to pickup like Roberts33 shows from the side 90 degrees from the original rotor orientation.
synchro1
George Chaniotakis runs three synchronous A.C. carousel motors in series; power diminishes with additional motors:
https://www.youtube.com/watch?v=f7mYsCEHLus
This is the same illusion. The series coils raise the impedance and restrict the current flow. The real test would involve determining how much pressure it would take to make the rotor slip. It looks like the 3 motors are doing the same work when it would only take a fraction of the pressure to make the rotor slip! Torque shy rotating turntable motors.
synchro1
Take a look at Lidmotor's "Zero Force Motor". I covered the effect of Lenz reduction from re-positioning the coil at 90 degrees earlier in this thread:
https://www.youtube.com/watch?v=IAYnppXT6NE
It's plain to see that the coil poles are on the vertical plain, directed up and down away from the diametric spinner by 90 degrees! Lidmotor is overunity, reading zero input, with Maggie for load!
John Bedini is an avid fan of mine.
