Thanks to ALL for your help!!
Im looking for an easy device
Started by LeksImpaler, September 06, 2014, 03:54:30 PM
LeksImpaler
Quote from: forest on September 08, 2014, 11:49:03 AM
Hi,
How good do you know spanish and english ? There is an important task of translating one or two patents from spanish language into english . Those patents seems easy to build but what is more important is the information included inside patent (which I fully support) which may be groundbreaking for you and others and which needs very precise translation. I do not know spanish (and english only a bit), so the progress in translating using google is very slow for me....
Hii!
Sorry for answering late.
Could you give me thats patents?
Thanks.
forest
Quote from: LeksImpaler on September 14, 2014, 01:46:47 AM
Hii!
Thanks.
I thought about Buforn patents (don't worry those few are repeating most of the same text so one is enough to translate plus some additional notes inside the others) : http://www.alpoma.com/figuera/buforn.pdf
Look at this thread for more information:
http://www.overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine#.VBVRTNJ_tSo
What  important  is ,that we can throw away all those zero point energy or ether, or even radiant energy topics. The fact is simple : Earth is a generator , powered by electric currents from space (probably from Sun). All inventors who told us about atmospheric electricity thought about those cosmic currents, not just ions in air.
Paul-R
Try this:
http://www.free-energy-info.com/Chapter10S.pdf
I think there is more here:
http://www.free-energy-info.com/Spanish.html
Be cautious about the translation. I do not know whether it Google Translate or whethe rPatrick had someone real to translate it.
Bob Smith
Quote from: forest on September 14, 2014, 04:41:59 AM
Forest (and anyone else),
Here's an interesting post on this point:
Quotei think earth has capacity to become negative pole than positive pole
few years ago i have "weird" result from my "ground" pole
i using earth as negative pole against positive pole from ignition coil
this setup make it as unusual electrical circuit
because usually if we use earth as "grounding" we attach it with negative pole of battery
but this time i am not connecting negative pole of battery to the ground
( i just connecting negative pole of battery to 555+Transistor and negative pole of ignition coil )
"theoretically" this circuit will not work ( positive pole of coil are not against negative pole of coil... rather it's agains "nothing" )
but i am surprize by it's result :
1. high voltage DC, jump between positive pole of ignition coil and the earth. as if the earth become negative pole
( just make few mm gap between positive cable from coil agains floor or soil will do the same )
2. in this electric jump, i heard "humming" or "cracking" sound
3. transistor become colder ( compared to "normal" setup )
4. 555 output freq seems increasing ( if we attach it to running LED or freq counter we get freq of circuit jumping )
and when i turn the potentiometer i am failed to change it's freq
as if it's freq lock in the circuit
Source: http://www.energeticforum.com/renewable-energy/1663-earth-rods.html#post262332
Regards,
Bob
burnit0017
https://www.youtube.com/watch?v=7ZCrcyeGhRw
Hi, this is a fun build. I am adding a twin bob pendulum driven by electromagnets. Using overrun clutch to drive a large flywheel.
