Thanks to ALL for your help!!
Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
MarkE
Quote from: ltseung888 on August 12, 2015, 06:13:27 PM
Waveform across 1 ohm resistor.
Does the waveform make sense?
The waveform shows obvious effects of ESL.
MarkE
Quote from: ltseung888 on August 12, 2015, 06:21:54 PM
John Bedini and many others are fighting against the USA Government...  The many UFO researchers are doing the same.  UFOs are known for much longer than 35 years.
Will US or Chinese Governments disclose the top secret?  Or will some other Nation do it?
Will Hong Kong University or any other academic institution publish the scientific data on the magnet repulsion experiment?  Will the governments suppress such research?
Lawrence
http://www.overunityresearch.com/index.php?topic=2100.msg50206#new
Lawrence, you do yourself no favors by defending the likes of Bedini.
ltseung888
MarkE
Quote from: ltseung888 on August 12, 2015, 08:00:27 PM
Input waveforms
Do you suffer from the misconception that your resistor is free of inductance, or that your scope probe does not require power from the circuit under test?  If you are using a function generator, set the pulse up as a trapezoid and vary the rise time over a range from say 10 times what it is now to 1/10th what it is now and watch what happens to your wave forms.
Both channels have bandwidth limiting turned on, and CH2 is AC-coupled. Why?
