Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
Summary on Aug 15, 2015
Mr. Lee Cheung Kin, the scientist who first proposed that gravitational energy could be lead-out via a horizontally pulsed pendulum, passed away on July 9, 2015.  His proposal was turned into mathematics by Lawrence Tseung.  Such a proposal would not violate the Law of Conservation of Energy.  However, it opened a new line of scientific thinking.
If gravitational energy could be lead-out, magnetic or electromagnetic energy could be lead-out also.  The 188 HP Laing Car, the Wang Shen He Magnetic Motor, the 225 HP Pulse Motor, the Tsinghua Energy Multiplier, the Milkovic two stage pendulum and the Chan Wheel etc. would not be hoaxes.
The QMOGEN patent granted to Jesse McQueen in 2006 by USA is valid.
The work of Bedini, Newman, Steven Mark, Witts Ministry etc. all have solid scientific backing.  The latest ninth design of the Flying Saucer based on varying the speed of the magnet in circular motion is scientifically sound.
All points to the fact that the lead-out energy flying saucer is possible and may have already been implemented by USA and Chinese Military.  They are keeping this technology top secret as it will lead to a new paradigm.
A simple scientific experiment comparing the Input Electrical Energy and the Output Potential Energy of a magnet or a coil is proposed and turned into student projects at Hong Kong University.  This experiment will change the academic thinking forever.
The 60 reported QMOGENs and the "free energy" researchers will be viewed in a different light.  The World will be able to use abundant, pollution free, readily available lead-out gravitational or electromagnetic energy.  The electron motion energy of atoms may be used without the need for chemical reactions.  The new paradigm of lead-out energy flying saucer will come in the foreseeable future.
USA or China may disclose the top secret.  Or a third Nation will do so to benefit the World.
ltseung888
Quote from: MarkE on August 14, 2015, 06:39:05 AM
As long as you use a cement resistor as your current sensing device the leading and trailing edge measurements will be fouled up.  If you are serious you can surely spend the small amount of money needed to buy a proper current sense resistor.
It does not matter at this stage as the experiment is in the first crude stage.  We should not rely on the hand-pushed switch.  We should not have hand-winding.  We should use thicker wires and higher current,  We should use two iron-core coils.  We should use better ferromagnetic material than the iron rods, etc.
All these will be improved by the Students at Hong Kong University or other top academic institutions.  They will catch the Big Fish and shine...
There is no time pressure.  The Flying Saucers from USA and China are already flying...
MarkE
Invest in minimal fixturing to take accurate measurements or don't.  Work with small error bars or gigantic ones.  It is all up to you to try and make your case for your claims.
ltseung888
Quote from: ltseung888 on August 14, 2015, 12:52:58 AM
Air core waveforms.
Top is with magnet inside tube jumping.
Bottom is with no magnet.
*** From preliminary measurements, the Input Electrical Energy to the air-core and iron-core were approximately equal.  It was mainly number of turns dependent.  However, the magnetism from the iron-core was many times that of air-core.  The result is in line with known properties of electromagnets.
*** This points to the possibility of Electrical Input Energy may be less than the Output potential energy of a magnet or a coil.  More experiments are needed but we shall have dozens if not hundreds of students working on it.
Lawrence
http://www.overunityresearch.com/index.php?topic=2100.msg50206#new
If less energy is required to align the "magnets or dipoles" in ferromagnetic materials than the resulting magnetic energy available, we have a clear case of lead-out energy.  The experiments so far point to this direction.  More experiments will be done to confirm this.
The remaining question is - if we use this energy, how would this energy be replenished?
Are there more onion skins to be peeled than stated in textbooks???
ltseung888
Quote from: MarkE on August 14, 2015, 06:40:10 PM
That was my mistake in the past.  Try to use limited resources to do the impossible.  Try to row a boat across the Pacific.
The correct path is to pass the responsibility to the groups with proper resources.  The late Lee Cheung Kin took the right approach - just pass the research results to his contacts.  USA and Chinese Military have succeeded.  They are keeping the technology top secret.  Will another Nation or other small academic institutions "rediscover" the top secret?
There is no need for me to make any case for my claims.  There is no pressure on the academic institutions. The UFOs are flying...
