The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
gotoluc
Quote from: lumen on December 18, 2014, 09:05:34 PM
To get around the Lenz problem,  you put the magnet and the core inside the coil and use iron to pull the loops outside the coil.
With this reverse Lenz effect as the iron attracts the loops outside the coil they must pass through the coil inducing a current that instead attempts to retain the magnetic loops inside the coil. Whatever is held inside the coil causes less attraction to the rotor that's trying to pull the loops out.
If this was designed well, you should be able to pull as many loops out through the coil as you could push into a coil in a typical generator. The difference would be that additional load would not need additional work from the Lenz effect because you have reversed the direction of Lenz by inverting the magnetic field in the coil to the rotor direction.
Hi Lumen,
you're making me think and interestingly I stumbled upon this video today and was wondering if this would qualify as a Lenz work around design?
I chopped the original video to get to the final design.
http://www.tubechop.com/watch/4385356
Please let me know what you think
Luc
lumen
Quote from: gotoluc on December 18, 2014, 11:34:59 PM
Hi Lumen,
Luc
Luc
I think it can be done much easier. I'll post a drawing of my new test device after I measure the coil and draw it up. It's much less complicated.
gotoluc
Great lumen!
Looking forward to see the design you have come up with.
Thanks for sharing
Luc
Jimboot
Quote from: lumen on December 19, 2014, 12:03:12 AM
Luc
Hi lumen please post when you can. I'm looking forward to seeing it. I think you right that the lenz is certainly present, but the rotor material in this design will not see as it flips to become part of it. Anyway just a gut feel,
lumen
This arrangement should prevent Lenz in the coil from affecting the rotor if that is possible.
The key factors are:
1: No movement between coil and magnet.
2: The field propagates outward as the rotor approaches the core and propagates into the core as the rotor moves away.
The idea is that Lenz will work to contain the field within the core as the magnet tries to push it outward into the rotor.
With Lenz working against the magnet not against the rotor.
When the rotor is moving away, Lenz will push back against the collapsing field and prevent pulling back on the rotor.
The total pull back on the rotor to the core can only be the same as the pull into the core as the field would be the same magnitude minus some losses from other events.
This is only a concept until proven to work anything like described.
