0 Members and 57 Guests are viewing this topic.
It is really unfortunate that even Nikolayev doesn't demonstrate the _really interesting_ behaviour of Marinov's version of the Siberian Coiliu. The thing that Jeffrey Kooistra called the "Warlock's Wheel".
In the first clip above, the presenter (is it Gennady himself?) cleverly breaks the connection at the right time, so you don't see how the rotating magnet "locks" into position when the current in the ring remains on. By timing the interruptions properly a very interesting pulse motor can be made. Years ago when I was experimenting with these devices I made what I call the "Marinov Slab" motor which is essentially that.
(The second clip above is just another HoJo or "vgate" SMOT.)
I also constructed a testbed device, long since lost, that demonstrates the actual interesting phenomena of the Siberian Coiliu as Stefan Marinov showed it. It is so strange that nobody even believes it can happen so you do not see any analyses of it presented anywhere, except Jeffrey Kooistra's work in Infinite Energy magazine, before Gene Mallove was killed.
Here it is in a nutshell. Imagine, in the first clip above, that the Ring is also free to rotate, and has some radial thickness. I used a copper vacuum gasket for my ring. The input power feed is made by two liquid metal "brushes" that contact the mobile ring where the feed wires contact the fixed ring in the video clip. Now, when the brushes contact the outer edge of the ring, and power is applied, the magnet armature moves just as shown in the video (it takes the shortest way around to the "lock" position at 90 degrees to the feed points) and the "stator" Ring rotates in the opposite direction. So the ring and stator are pushing against each other, one goes one way and the other goes the other way. Interesting but not too unusual and not really unexpected. Now... move the brush contacts so that they contact only the _inner edge_ of the mobile ring. Apply power and observe: the magnet armature rotates as before, and the ring rotates IN THE SAME DIRECTION.  By pulsing the power, the armature and ring can both be made to rotate continuously IN THE SAME DIRECTION.
These remarkable effects are due to a definite cause, and it has nothing to do with the imaginary fictions depicted in the graphics above. Does it violate Newton's laws of action-reaction? That, I will leave as an exercise to the interested experimenter. But of all the devices I've examined, built or read about, this one and my forced precession gyro apparatus are the two that genuinely exhibit behaviour that is completely unexpected and startling.
I would really like to demonstrate this, and a handful of people have seen my apparatus in action, fifteen years ago at the ISSO laboratory in San Francisco. But that apparatus is lost and I've not been able to construct another one. However, Jeffrey Kooistra's apparatus was far simpler (and more artifact-prone) and the phenomena I describe above can at least be demonstrated using his setup to show that it indeed works as I say. He used a styrofoam cup, a copper ring, small puddles of mercury on a flat surface, bar magnets, and foil feeds to the mercury pools to bring in the power. In the "lost" apparatus I used triaxial suspension of a magnet rotor, the copper vacuum gasket "stator" and a completely selfcontained power supply/brush structure that could be turned on by a laser pointer beam hitting a photodetector, so that all three parts could rotate independently and nothing outside the system itself could be accused of moving anything.
Here's a picture of the Marinov Slab pulse motor: This works exactly like the demonstration in the first Nikolayev clip above except that the current interruption is done by Hall-effect switching, so it rotates consistently in one direction.
Quote from: EMJunkie on April 22, 2015, 06:50:56 PM
MarkE - I have already shown all the concepts I need in my videos. None of these videos have been refuted. In-fact, many others out on the internet have replicated my work. Much of these replications are within the Russes Mother Land, where Fluoride is not putting minds to sleep, where Vaccinations are not sterilising people by the millions, where their own government does actually work for the people.
You have proven yourself to be a Goon many times, a smart person that can not think for himself.
MarkE, I am afraid it is too late for you, but I am ok with that, we all make educated decisions for ourselves, all I see is what I have said: "It seems that the Eyes are a sensory perception that is very much Censored by Perceptions"
Where your perceptions are from a Textbook that is written to blind and fragment reality.
Ever heard of "The Black Knight"? - How is it, that, 13,000 years ago, a bunch of people that were banging other people over the head with Rocks could launch something like this into Orbit? Or could it be that the very History Book you believe in, may not contain the correct information?
As usual. When you are challenged to support your claims, it becomes evident that YOU CANNOT, so you fall back into the tried and true tactic of almost every false claimant: you start insulting and you come up with irrelevant BS in an attempt to distract the readers from focusing on the FACT that you can't provide any evidence for your false claims. Do all of your ilk have identical copies of the same script, I wonder? I mean there is so little variation in your behaviours that it's uncanny.
MarkE
Quote from: allcanadian on April 22, 2015, 07:20:40 PM
@Mark E
Myself and another witness saw that the whole body of a smaller second craft which came from a first very large one was illuminated a dull orange color. There was no sound, no jet plume from a rocket nor was there a vapor trail. The smaller craft accelerated to an absurd speed made a wide 90 degree sweeping turn upwards and just accelerated almost straight out and away from the Earth as far as we could see.
So you cannot and did not see anything leave earth's orbit but merely leave your sight.
This observation led me two believe either the craft had an energy source we cannot possibly imagine or somehow it had manipulated the property of inertia. I think you might agree that it takes a great deal of energy to accelerate a mass against the force of it's own inertia. Thus either the energy source was very great or the inertia was somehow very low.
F=mA.  Inertia is not a force, mass doesn't have force.  It requires force to accelerate a mass.  Absent a RADAR or other suitable distance and time measuring equipment it is unlikely that you or your compatriot could assess either speed or acceleration of a distant object.
As you can imagine I have tried to relate this observation to known phenomena, as you say, things we can prove however I cannot reconcile what we saw. I mean I have seen F-16's dog fighting at low level and breaking the sound barrier, I have seen a missile fired from close range accelerating over the horizon and I am familiar with more aircraft than most anyone I know...this was not what I saw. There is literally nothing I know of that can accelerate that fast or make that kind of super high G turn or leave the Earths atmosphere at that velocity, I meant to say earth's atmosphere in my last post.
Again, leaving your sight does not translate to leaving the earth's atmosphere.  Unless you could assess time and distance you could not assess the second derivative acceleration no matter what your perception told you.
So I am left to speculate that it must be using technology we cannot understand yet because according to the laws of physics I know no craft can do what we saw it do. Which raises the question, if it was not a conventional propulsion technology(no sound, plume or vapor trail) then what was it?. I would guess it must somehow relate to electrodynamics hence my comment regarding Faraday and Lenz law.
So you have taken a dodgy observation and let your imagination and pure speculation do the rest.
I guess the issue which is not uncommon is that the facts I know and have seen first hand are not the same one's you have seen and know. Such is life
Perceptions are often wrong.  That's one of the reasons why we have instruments and conduct null experiments.
AC
Enjoykin
Tomsk Professor Gennady Vasilevich Nikolaev (1935-2008).
So on above videos is not Gennady Vasilevich Nikolaev but Valeryi Belousov. Videos are from 2015.
They are links on many original experiments by Gennady Vasilevich Nikolaev.
https://www.youtube.com/results?search_query=+%D0%93.%D0%92.+%D0%9D%D0%B8%D0%BA%D0%BE%D0%BB%D0%B0%D0%B5%D0%B2
For example video 2h:52min:50sec
Геннадий Николаев. Скалярное магнитное поле
Gennady Nikolaev. Scalar Magnetic Field.
https://www.youtube.com/watch?v=bZbDhx6earA
Подшипник без шариков Николаева Г.В.
Gennady Vasilevich Nikolaev - Magnetic bearing without balls.
https://www.youtube.com/watch?v=MOE78EHEuFE
Продольные Волны - Опыт - Г. В. Николаев - Сибирский Коля
Longitudinal waves-  Exeriment by  Gennady Vasilevich Nikolaev - SIBERIAN COLIA
https://www.youtube.com/watch?v=0mpAHd-iriA
Второе Магнитное Поле - Николаев - Сибирский Коля
Second Magnetic Filed - Gennady Vasilevich Nikolaev  - SIBERIAN COLIA
https://www.youtube.com/watch?v=xpdFMbIcmD4
On this link you will find a many links to Professor Gennady Vasilevich Nikolaev science books so you can download and make OCR conversion. In the book "Un-paradoxical Electrodynamics" you will find a lot of explained experiments and how-to tips.
http://www.overunity.com/14755/hogan-and-jakovlewich-overunity-generator/msg447253/#msg447253
PS: SIBERIAN COLIA is Dr. Stefan Marinov name of Gennady Nikolaev magnet configuration. He was good friend and colleague of Gennady Nikolaev untill 1997 when he has been killed in Austria - several days before presentation of his perpetum mobile in Munich.
EMJunkie
Quote from: TinselKoala on April 22, 2015, 10:21:19 PM
TK, a 49 page pdf, several videos showing anonymous effects and some 700 + posts here and other forums.... No support...
Hahaha - your stupidity along with MarkE's is just laughable.
You and MarkE are simply Villainous Juveniles with nothing better to do in your Lazy Retirement Days!
