0 Members and 94 Guests are viewing this topic.
jbignes5
So did my post get any response? EMJunkie? Or did all the flim flam from these "Police" get you so sidetracked that you missed the very source to the technology you are describing?
It is very important that you understand that this has been replicated successfully by Tariel Kapanadze. At least he admitted who it came from and LEARNED how to use it for real power applications. You are trying to reinvent the wheel when the wheel is taking you down the road. Tesla is the teacher and we should all listen and replicate the technology that was suppressed from the beginning. Find my posts and read everything I linked to. Yes Tesla was just delving into this new phenomena but I suggest he knew more than we could ever imagine.
Don't let the measurement police get to you. In all budding technologies there is an exploration period. In that period there is little by way of power statements because as you have eluded we need to understand the event before we try to explain the output vs the input. In fact if we look we are converting one form of energy into another by our "Transformation" as you have noted. The first form of energy is rarely noted to be useful but without it no energy could exist. Let me explain:
Potentials and a gradient of potential is what we are looking at. If there is no potential difference there is nothing. But creating a difference like a slope will enable that potential difference to act. That act is called Energy or the flow of energy. Magnetics is a result of the potential difference in motion. Magnetics also is very wasteful. So in order to get this to work properly you need to contain the magnetic to purify the electric field and free it. The electric field is the sole entity responsible for generation from a moving rotor and not the magnetic. The magnetic field is the reason for Lenz's Law. The MF is also the sole reason there is no perfect generator yet. Tesla liked to call his special generators Revolving Transformers. Now why is that?
You ever wondered why Tesla won over DC? Because he could raise the potential so high that literally no current could be lost in the transmission over 1000's of miles. Even if the system radiated a high electric field the amount of current lost in that transmission over those 1000's of miles would be moot. It works, plain and simple. <-Hint
JBignes5
EMJunkie
@ALL,
This is a little off topic, but relates. I will try to be brief!
About three years ago I got the Vacuum Cleaner out to do some Vacuuming around the house. (Yes I do it regularly  ;))
I plugged it in, went to turn it on, and POP! I thought this was very strange!
Pulled the Cleaner down and tried to find what was going on. I found that one of the Field Coils had blown itself to bits, approximately 1 cm of wire gone. Minimal Burn Marks!
The Rotor was stuck in one position, it could move but not freely like normal!
With my work I was doing (Related topic) I could only come to one conclusion why this happened.
I believe that the same situation as we are looking at right now had presented itself in the Motor! Magnetic Field's Build, some in opposition, and because the Rotor was stuck, we got Max Fields!
On collapsing with the sine of the mains I believe this Magnetic field went to Max Current and as a result the wire could not handle this huge current and it blew to bits.
I have of course assumed that this was the situation! I have no proof that this is what happened.
So, the point of me posting this, is that we need to Maximise the Magnetic Field Interactions! Get the highest Magnetic Fields in the device that are possible.
Hope this helps!
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
EMJunkie
Hi JBigness5
Missed Sorry!  :)
Quote from: jbignes5 on January 21, 2015, 05:12:57 PM
Again this is nothing new.
Yes, I know, I have stated this in my pdf document - The big difference is I am trying to make people publicly aware! No-one else has done this before.
http://www.tfcbooks.com/tesla/1891-05-20.htm
Figure 113 is the method you are talking about.
The text I believe has been altered to deter the meaning of this setup.
This would not surprise me at all!
"The above described arrangements refer only to the use of commercial coils as ordinarily constructed.  If it is desired to construct a coil for the express purpose of performing with it such experiments as I have described, or, generally, rendering it capable of withstanding the greatest possible difference of potential, then a construction as indicated in Fig. 17 / 113 will be found of advantage.  The coil in this case is formed of two independent parts which are wound oppositely, the connection between both being made near the primary.  The potential in the middle being zero, there is not much tendency to jump to the primary and not much insulation is required.  In some cases the middle point may, however, be connected to the primary or to the ground.  In such a coil the places of greatest difference of potential are far apart and the coil is capable of withstanding an enormous strain.  The two parts may be movable so as to allow a slight adjustment of the capacity effect."
Another reference to this design is also a Tesla creation:
http://www.tfcbooks.com/tesla/1892-02-03.htm
Figure 3 is also this design slightly changed for very high voltage use.
I can only say here that others should not limit them selves. My devices work at lower Frequencies and lower voltages - We don't want to over do it and do any damage!
If you read the whole document you will see it is mostly about very high frequencies and very high voltages. Their separation and use after the separation. Figure 17 shows a one terminal Motor and how to use it with this type of system of very high frequency oscillations which was proven by Kapanadze in his video's as well.  Shown here https://www.youtube.com/watch?v=qVUN3GsekKQ
JBignes5
Yes, Kapanadze could be considered to also use this technology!
I suggest to people, start small, don't get tied up with huge expectations! Light a Light first! then move on from there!
JBigness5, youre right, Tesla had and knew about this Tech! Many hundreds of others have also known!
It takes some understanding and some experimentation to move forward, like I said, don't expect the first device to work. It could one of ten that may work! If all follow my guidelines then it will make the whole thing SO much easier however!
Kind Regards
EMJunkie
@JBignes5,
Quote from: jbignes5 on January 23, 2015, 04:51:28 PM
Yes, I am sorry!  :)
Kapanadze is just one implementation of this tech, there are many! See my pdf for a small list, by no means complete!
I have tried to stay away from this area, to try not to confuse people. Energy is still Energy, weather it is Tom Beardenized or not, if you don't mind my terminology. It come slightly different because of the conditions, I cover this in my pdf also.
Let me explain:
Hahaha, yes Sir, you're exactly Right!
JBignes5
AC is superior to DC, always will be. DC still has its uses of course.
AC is Natures Wave, everything in Nature has an AC Wave component to it! Tides, Light......
Kind Regards
John.K1
Hi EMJunkey, I just wonder how big role here plays the core. You  said you have no luck with air core? Why?  The principle should be still the same. Generation of two opposing magnetic fields. Unless you need some sort of medium for accumulation and time propagation of the magnetic field. Take a look at the pages of Steorn ( may be you remember their free energy device-motor, the device was also shown publicly and now for many years quiet. On their pages you can download some interesting pages ;)  http://www.steorn.com/orbo/papers/
Good luck
