Cap-Z-ro
Quote from: EMJunkie on January 23, 2015, 11:23:24 PM
Sorry Cap-Z-ro , not meant for you!
Peace, let the smoke rise up!!!
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
Alls swell on the western front Chris.
Just a little self deprecating humor, masking a penchant for the crime of Alfred Webre's hair being stolen...likely at an alternative energy trade show by one of the venders, who made off in a strangely silent scooter.
Nooz @ Elebben
Regards...
EMJunkie
Quote from: Cap-Z-ro on January 24, 2015, 12:13:00 AM
Nooz @ Elebben
Regards...
Hahaha you did warn us! Good humour!
Back at you!  ;)
@ALL - Please vote in the pole if you have not already!
Kind Regards
wistiti
Quote from: EMJunkie on January 23, 2015, 05:05:16 PM
So, the point of me posting this, is that we need to Maximise the Magnetic Field Interactions! Get the highest Magnetic Fields in the device that are possible.
Hope this helps!
So if i understand correctly you mean more turn in the trigger coil and more turn in the partner coil. Or put and higher voltage to the trigger coil...?
EMJunkie
Hey Wistiti,
Quote from: wistiti on January 24, 2015, 12:21:28 AM
Its a little bit of a balancing act! Make sure you have enough turns to get the Magnetic Field up!
The Magnetic Field is calculated by: B=μI*n/l
B = Magnetic Field
μ = Permeability
I = Current
n = number of turns
l = Length of the coil
So one must make sure that the Magnetic Field is enough to start the process going! No, or not enough Magnetic Field, very little or no effect! Same it true if the Magnetic Field is choked off!
Stick to the turns suggested in prior posts. All should be ok with them.
Kind Regards
wistiti
hi all!
my result until now. (with what i have on hand...)
Tv yoke split in 2 part as the core.The 2 peices of the core have a gap of around 2mm with electric tape and paper. Buckink coil wound on each part of the core 400 turns 30awg each coil. Primary (or trigger coil) 2 strand twisted litz like wire 50 turns over one secondary coil. The primary (or trigger coil) is trigger with a joule thief like circuit. I have a 50k resistor to the base of a 2n3055 transistor for adjusting the frequency.
My result clearly depend on the frequency... at some point, when the output is shorted, the amp draw on the input goes higher. But when i tune it to is best, the input went to 400ma no load to 293 shorted! there is definitely something there...  :)
