0 Members and 64 Guests are viewing this topic.
EMJunkie
Quote from: TinselKoala on May 27, 2015, 06:43:02 AM
You are back to your irrelevant insults again, I see. A leopard doesn't change his spots, and you, being the False Claimant that you are, will never change either. You cannot refute me, you cannot perform adequate tests and measurements yourself, so you just insult, post irrelevancies and interfere with good work that is being done and discussed here. And you take every opportunity to prove your incompetency and untruthfulness!
Hahahaha - You going to be ok TK?
Insinuating I am a:
False Claimant...
Only says this about your personality:
verb (used with object), insinuated, insinuating.
1. to suggest or hint slyly: He insinuated that they were lying.
2. to instill or infuse subtly or artfully, as into the mind: to insinuate doubts through propaganda.
3. to bring or introduce into a position or relation by indirect or artful methods:
to insinuate oneself into favor.
verb (used without object), insinuated, insinuating.
4. to make insinuations.
I already know, but others may think you're a bit of a low life if you keep Insinuation and doing what your country does best, Propagandising.
Got the Time TK?
   Chris Sykes - because I can and have and TK hasn't and cant  ;)
       hyiq.org
EMJunkie
Quote from: minnie on May 27, 2015, 06:51:17 AM
     Go back to basics and work like Henry and Faraday did.
Oh, yes, John it is far more basic than you think. See the problem is, Heinrich Lenz's was after Faraday! But the facts some can not see!
There in lies a test, to see if you are able to solve for the solution to the riddle?
   Chris Sykes
       hyiq.org
madddann
Quote from: tinman on May 27, 2015, 06:17:02 AM
Yes.
No.
I dont know what you mean by heat taking an average path?.
You may be supprised.
But lets keep it close to my experiment.
Lets run the light bulb on 3 volt's @ 191mA at a duty cycle of 95%. This is 573mW of power going to the globe.
Then lets switch to 20 volt's @ 15.82mA at a duty cycle of just 5%. This is 320mW of power.
Now which one do you think will make the light bulb brighter?.
Enjoy.
https://www.youtube.com/watch?v=Ct2Ks44ZZ9c
Wow! Already uploaded a video?
I gave you thumbs up for real experimenting work!
...but you did it again - took the average voltage and current (for this case, this method is not correct in my opinion)
Have a look here for info: http://www.electronicspoint.com/threads/calculate-pwm-power.243414/
... If you can, do as TK says in post #3079...
Hopefully we all can learn something...
EMJunkie
@All - I am seeing this everywhere, lies from the governments!
Sinkholes are due to Earth Crust Displacement.
Don't let the lies suck you in!!!
Sorry for the pun  :)
   Chris Sykes
       hyiq.org
poynt99
Quote from: tinman on May 27, 2015, 01:53:36 AM
I guess there are those you trust,and those you dont Chris.
Poynt happens to be one of those i trust-although i am a little disheartened that he thinks that what he tells me falls on deaf ears-->but it dosnt. It gives me the drive to check and recheck my work,and this is what i have done throughout my experimenting.
Chris,believe me when i say that Poynt is NOT some one that will do wrong by anyone here. He has done nothing but help me since i joined OUR-->even to go as far as taking the time to talk me through devices on the phone,or by skype. You dont get this often,as most simply dont have the time for amatures like myself.
My point is-GOD him self could come and tell me i have nothing out of the ordinary going on,but if i believe i do,then i will keep on going until i either find out my self i dont,or some one else see's something interesting happening-->as you did in that email i sent you.
I guess we just go about things differently when we see something interesting.
You come straight out and say-free energy device,where is i sneak out bits and pieces,and then let others find a similar effect. There also needs to be care taken where you post what,and who you share what with. You have found out first hand what happens when you just pop up and scream !free energy device!-->the sh-t hit's the fan. I have chosen to share my design openly,but take care when showing first stage results.
You must remember-->those that live and breath convention,will only ever see convention. This means that the unconventional will be missed. They are taught and believe they will see only conventional,so they become blind in an unconventional way.
As you have seen,it is a close call,and there is room for error,but im not sure how you could screw that test up i showed you ??? The P/in and P/out couldnt be much more simpler.
Good on you Brad. I do admire your strive towards the truth on your own terms. That's the only way really.
Glad you're taking into consideration what others advise as well. :)
Cheers.
