0 Members and 60 Guests are viewing this topic.
EMJunkie
This is quite a good Video, all about Self and Un-Selfish: https://www.youtube.com/watch?v=PWcHATYC6X0
Now I know how MarkE was Conceived!
   Chris Sykes
       hyiq.org
picowatt
Quote from: EMJunkie on June 25, 2015, 06:51:31 PM
@All - PW (Picowatt) is a government agent - Deny Everything - Remember this!!!
Do not trust this person, he is deliberately misleading you! All of the Goon Squad are!
   Chris Sykes
       hyiq.org
How is it "misleading" to believe Tinman's explanation of his own circuitry over Syncro1's speculation?
Tinman says he shorts one of his coils at a particular time in his generator's cycle.
I have no reason to believe he does otherwise.
picowatt
Quote from: EMJunkie on June 25, 2015, 06:32:00 PM
There is only ONE WAY that Partnered Output Coils can work when they are Paralleled Up as Tinman has shown! If you find the answer to what I have said, the proof will be in the pudding! I have shown that Points A and B prove this!
At no time are Tinman's generator coils "Paralleled Up", nor does Tinman electrically parallel his second generator coil with the output as you indicate in your redrawn and simplified schematic.
Why are you and Synchro1 so intent on rewriting Tinman's explanation of the operation of his own circuit?
If you are unable to understand the schematic Tinman graciously provided, perhaps you should just say so and ask questions...
EMJunkie
Quote from: picowatt on June 25, 2015, 09:27:32 PM
EDIT: After I posted:
At no time does Tinman electrically parallel his second generator coil with the output as you indicate in your redrawn and simplified schematic.
PW - First of all, this is Tinman's Original Circuit - I have posted below, again for your Exceptional Observational Skills!
Shorting Coil B, Dumps the Output Capacitor Voltage through the drawn resistor. First, this would have been very clearly visible on the Scope Shots that Tinman has provided! It is not!
Quote from: tinman on June 22, 2015, 06:48:14 AM
Isnt that interesting woopy. Now what do you think would provide a greater magnetic field?--> a shorted coil with a 50 volt potential across it,or a shorted coil with a 250 volt potential across it?. If you use your scope with a CVR to view current,and the other trace to view voltage,you will see that they are very near in phase,and thus by increasing the voltage across the coil-(even if the current remains the same) the produced magnetic field during that short is far greater than if there was no short. An open coil produces nothing. but a shorted coil at the right time produces a very strong magnetic field. Now all you do is add a second field that apposes that produced field to gain mechanical rotation torque increase. When the torque is increased,then RPM increases when the motor has a load on it,and as the RPM's are increasing,the current draw is decreasing.Also,as the RPM's increase,the generated power output also increases.
Two things to remember woopy.
1-a transistor or mosfet can be switched on two ways.
2- When an inductor becomes open circuit,the current flow remains in the same direction,but the voltage polarity switches.
Correct.
Everyone is looking only at the electrical output of my device,and seem to be ignoring the mechanical output that is also there.
They also dismiss EMJ's shorted coil theory,and although he hasnt shown a working device yet,and he messed up the scope measurements,his theory is sound.
How about you kick in a bit of Common-Sense! "Use your Own Brain" as Tinman said and as I have tried to encourage! I mean, where in History, has OU been seen when Dumping a Capacitor Voltage across a Resistor?
If shorting of Coil B was really whats going on, why on Earth would each Coil A and B be Paralleled Up? AC across a DC Cap? Really, Picowizzard, what's going to happen here? Are you really this stupid? There are so many blatantly obvious problems with this Circuit and the description given! Are you able to comprehend any of them?
Picowizzard, time to pull your socks up old mate.
   Chris Sykes
       hyiq.org
picowatt
Quote from: EMJunkie on June 25, 2015, 10:07:57 PM
It is clearly shown in Tinman's schematic that Coil A and Coil B are not "paralleled up".
You are apparently intent on seeing what YOU want to see, not what is drawn.
